请指点一下
1530|0
my831029|  楼主 | 2008-9-26 09:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ST, AN, se, USB, ip
Bus Hound 3.02 capture. Complements of www.perisoft.net
  Dev   - Device ID
  Time  - Elapsed time since the start of the previous Phase
  Phase - ADDR= 1394 transfer address  LOCK= 1394 lock transaction
          CDB = Command block          NSTS= NT status
          CTL = USB control packet     RSET= bus reset
          DI  = Data In                RSTS= I/O Request Status
          DO  = Data Out               SNS = SCSI Sense Data
          IDE = IDE task file command  SSTS= SCSI Request Block Status
          ISOC= Isochronous Transfer   USTS= USB status
  (8) Standard OpenHCD USB Host Controller
  (9) USB Root Hub
  (10) Standard Enhanced PCI to USB Host Controller
  (11) USB Root Hub
  (12) Standard OpenHCD USB Host Controller
  (13) USB Root Hub [18KB/Sec]
  (14) Standard Enhanced PCI to USB Host Controller
  (15) USB Root Hub [311KB/Sec]
Dev  Phase  Data                                                   Info              Time   Cmd.Phase.Ofs
 15  CTL    a3 00 00 00 - 05 00 04 00                              CLASS               0us         1.1.0
 15  DI     00 85 01 00                                            ....               14us         1.2.0
 15  CTL    a3 00 00 00 - 05 00 04 00                              CLASS              16us         2.1.0
 15  DI     00 85 01 00                                            ....               13us         2.2.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS               7us         3.1.0
 15  CTL    23 01 10 00 - 05 00 00 00                              CLASS               3us         4.1.0
 13  DI     01 03 01 00                                            ....               13us         3.2.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS              12us         5.1.0
 13  DI     01 03 01 00                                            ....               14us         5.2.0
 13  CTL    23 01 10 00 - 05 00 00 00                              CLASS               8us         6.1.0
 15  CTL    a3 00 00 00 - 01 00 04 00                              CLASS              10us         7.1.0
 15  DI     00 05 00 00                                            ....               13us         7.2.0
 15  CTL    a3 00 00 00 - 02 00 04 00                              CLASS               9us         8.1.0
 15  DI     00 05 00 00                                            ....               13us         8.2.0
 15  CTL    a3 00 00 00 - 03 00 04 00                              CLASS               9us         9.1.0
 15  DI     00 05 00 00                                            ....               13us         9.2.0
 15  CTL    a3 00 00 00 - 04 00 04 00                              CLASS               7us        10.1.0
 15  DI     00 05 00 00                                            ....               12us        10.2.0
 15  CTL    a3 00 00 00 - 05 00 04 00                              CLASS               7us        11.1.0
 15  DI     00 85 00 00                                            ....               11us        11.2.0
 13  CTL    a3 00 00 00 - 01 00 04 00                              CLASS              21us        12.1.0
 13  DI     00 01 00 00                                            ....               17us        12.2.0
 13  CTL    a3 00 00 00 - 02 00 04 00                              CLASS               8us        13.1.0
 13  DI     00 01 00 00                                            ....               11us        13.2.0
 13  CTL    a3 00 00 00 - 03 00 04 00                              CLASS               9us        14.1.0
 13  DI     00 01 00 00                                            ....               11us        14.2.0
 13  CTL    a3 00 00 00 - 04 00 04 00                              CLASS               8us        15.1.0
 13  DI     00 01 00 00                                            ....               11us        15.2.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS               7us        16.1.0
 13  DI     01 03 00 00                                            ....               11us        16.2.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS             124ms        17.1.0
 13  DI     01 03 00 00                                            ....               14us        17.2.0
 13  CTL    23 03 04 00 - 05 00 00 00                              CLASS               8us        18.1.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS              10ms        19.1.0
 13  DI     03 03 10 00                                            ....               15us        19.2.0
 13  CTL    23 01 14 00 - 05 00 00 00                              CLASS               3us        20.1.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS              21ms        21.1.0
 13  DI     03 03 00 00                                            ....               14us        21.2.0
 15  USTS   00 00 01 c0                                            canceled          796ms        22.1.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS             4.6sc        23.1.0
 13  DI     03 03 00 00                                            ....               23us        23.2.0
 13  CTL    23 03 04 00 - 05 00 00 00                              CLASS               9us        24.1.0
 13  CTL    a3 00 00 00 - 05 00 04 00                              CLASS              10ms        25.1.0
 13  DI     03 03 10 00                                            ....               23us        25.2.0
 13  CTL    23 01 14 00 - 05 00 00 00                              CLASS               4us        26.1.0
 13  CTL    80 06 00 02 - 00 00 ff 00                              GET DESCRIPTR      92ms        27.1.0
 13  DI     09 02 22 00 - 01 01 00 a0                              ..".....          1.6ms        27.2.0
 13  CTL    80 06 00 03 - 00 00 ff 00                              GET DESCRIPTR      64us        28.1.0
 13  DI     04 03 09 04                                            ....              936us        28.2.0
 13  CTL    80 06 01 03 - 09 04 ff 00                              GET DESCRIPTR       7us        29.1.0
 13  DI     1c 03 55 00 - 53 00 42 00                              ..U.S.B.          1.9ms        29.2.0
 13  CTL    80 06 00 03 - 00 00 ff 00                              GET DESCRIPTR      10us        30.1.0
 13  DI     04 03 09 04                                            ....              989us        30.2.0
 13  CTL    80 06 01 03 - 09 04 ff 00                              GET DESCRIPTR       8us        31.1.0
 13  DI     1c 03 55 00 - 53 00 42 00                              ..U.S.B.          1.9ms        31.2.0
 13  CTL    80 06 00 01 - 00 00 12 00                              GET DESCRIPTR      51ms        32.1.0
 13  DI     12 01 10 01 - 00 00 00 08                              ........          1.7ms        32.2.0
 13  CTL    80 06 00 02 - 00 00 09 00                              GET DESCRIPTR       8us        33.1.0
 13  DI     09 02 22 00 - 01 01 00 a0                              ..".....          984us        33.2.0
 13  CTL    80 06 00 02 - 00 00 22 00                              GET DESCRIPTR       9us        34.1.0
 13  DI     09 02 22 00 - 01 01 00 a0                              ..".....          1.9ms        34.2.0
 13  CTL    00 09 01 00 - 00 00 00 00                              SET CONFIG          8us        35.1.0
 13  CTL    21 0a 00 00 - 00 00 00 00                              CLASS              19ms        36.1.0
 13  CTL    80 06 00 22 - 00 00 7f 00                              GET DESCRIPTR     389us        37.1.0
 13  DI     05 01 09 06 - a1 01 05 07                              ........          1.9ms        37.2.0
 13  CTL    21 09 00 02 - 00 00 01 00                              CLASS             1.0sc        38.1.0
我用busbone在xp下得到的数据,有这
是什么原因?
