CVI如何访问COM接口(DSP/RTDX)--武潭开弓第一水
4574|4
TI_CPIC| | 2008-6-12 08:57 | 只看该作者
支持一下!
hotpower|  楼主 | 2008-6-13 02:49 | 只看该作者
从注册表里取rtdxint.dll文件路径的方法
int DllFileNameSize;
char DllFileName[300];// = "d: iccin tdxint";
RegReadString (REGKEY_HKCR, "CLSID{2FE56670-3E4E-11D2-A964-006097A6A260}InprocServer32", "", DllFileName, sizeof(DllFileName), &DllFileNameSize);
hotpower|  楼主 | 2008-6-13 02:55 | 只看该作者
重新注册RTDX的COM接口
        if (status != S_OK)//建立IclassFactory接口失败自动注册
            hinstLib = LoadLibrary(DllFileName);
               // If the handle is valid, try to get the function address.
            if (hinstLib != NULL)
                //HRESULT CA_ServerDllRegisterServer (HINSTANCE server_hInstance);
                FunctionDLLRegisterServer = (DLLRegisterServer) GetProcAddress(hinstLib, (LPCSTR)"DllRegisterServer");
                if (FunctionDLLRegisterServer != NULL)
                    if (SUCCEEDED(FunctionDLLRegisterServer ()))
                        status = CoCreateInstance(&GUID_CLSID_RTDXEXINTERFACE,//COM class id
                                                  NULL,//outer unknown
                                                  CLSCTX_INPROC_SERVER,//server INFO = 从In-Proc Server 建立COM对象
                                                  &IID_IDispatch,//IDispatch id
                                                  (LPVOID FAR*)&pIDispatch);//pointer to pIDispatch
                FreeLibrary(hinstLib);
zealane| | 2008-6-13 14:06 | 只看该作者
hot大叔到处留香。。。。
叫h留香吧
