C2000 Delfino LaunchPad(TMS320F28377S)
楼主: zhangmangui
aaaxxxrrr| | 2017-1-25 09:56 | 只看该作者 回帖奖励 |倒序浏览
版主,这块板子的性能怎么样,我们打算买一个28377或者28379
zhangmangui|  楼主 | 2017-1-26 23:29 | 只看该作者
挺好的
1366545478| | 2017-2-2 11:21 | 只看该作者
建完工程ctrl+b后,出现50个错误。。。文件都添加了呀,报的错是这样的(部分):
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 7: error #10263:
   BEGIN memory range has already been specified
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 8: error #10263:
   RAMM0 memory range has already been specified
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 8: error #10264:
   RAMM0 memory range overlaps existing memory range RAMM0
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 9: error #10263:
   RAMD0 memory range has already been specified
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 9: error #10264:
   RAMD0 memory range overlaps existing memory range RAMD0
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 10: error #10263:
   RAMLS0 memory range has already been specified
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 10: error #10264:
   RAMLS0 memory range overlaps existing memory range RAMLS0
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 11: error #10263:
   RAMLS1 memory range has already been specified
"F:\ti\controlSUITE\device_support\F2837xS\v130\F2837xS_common\cmd\2837xS_Generic_RAM_lnk.cmd", line 11: error #10264:
   RAMLS1 memory range overlaps existing memory range RAMLS1
请大大指点,谢谢~
spray0| | 2017-2-3 17:53 | 只看该作者
"F:\ti\controlSUITE\dev ...
慢慢排除,思考流程,文件作用。这些东西需要自己走
zhangmangui|  楼主 | 2017-2-3 21:10 | 只看该作者
是不是存在两个CMD参与编译了工程啊
1366545478| | 2017-2-9 16:35 | 只看该作者
zhangmangui 发表于 2017-2-3 21:10
是不是存在两个CMD参与编译了工程啊
我把link的CMD文件删除后,就0个错误了,可以仿真;但是烧写代码固化的时候,把RAM文件换成FLISH文件后,编译没错后,无法烧写,出现loading program error。。。新手请教
1366545478| | 2017-2-9 16:38 | 只看该作者
嗯嗯,刚开始学DSP,CMD文件中连接作用还不是很懂
zhangmangui|  楼主 | 2017-2-9 21:18 | 只看该作者
1366545478 发表于 2017-2-9 16:35
我把link的CMD文件删除后,就0个错误了,可以仿真;但是烧写代码固化的时候,把RAM文件换成FLISH文件后, ...
这个只要编译没问题     一般out是咩问题的
你进debug应该就烧写进去了
tyq9702| | 2017-8-15 12:51 | 只看该作者
版主好,我按照您的步骤进行代码固化,在debug时点击Resume按钮,提示No source available for "0x3fe493"
请问这是怎么回事?
找到问题了,是因为我用了DELAY_US这个函数,将函数拷贝到RAM中运行就可以了。
zhangmangui|  楼主 | 2017-8-15 22:36 | 只看该作者
恩  不错    建议多分享一下
Fraisty| | 2017-9-8 21:27 | 只看该作者
大大 按照你的步骤走完也出现了楼上的50个错误,28377S_FLASH_lnk.cmd和2837xS_Generic_RAM_lnk.cmd 冲突了为啥呀
Fraisty| | 2017-9-8 21:53 | 只看该作者
Fraisty 发表于 2017-9-8 21:27
大大 按照你的步骤走完也出现了楼上的50个错误,28377S_FLASH_lnk.cmd和2837xS_Generic_RAM_lnk.cmd 冲突了 ...
换成2837xS_Generic_FLASH_lnk.cmd  之后不删28377S_FLASH_lnk.cmd的话错误更多了= =
zhangmangui|  楼主 | 2017-9-9 09:34 | 只看该作者
同时必须只有一个CMD存在
wannengaman| | 2017-10-23 07:25 | 只看该作者
牛人! LaunchPad(TMS320F28377S)真是既便宜又强大!
zhangmangui|  楼主 | 2017-10-24 23:20 | 只看该作者
用起来了吗
zhangmangui|  楼主 | 2018-9-17 22:05 | 只看该作者
顶一下     这个应该能帮到初学者
混子黄| | 2018-10-16 14:51 | 只看该作者
支持斑竹,希望在出一个launchxl-f28379d的教程,虽然应该差不多,但是双核应该麻烦很多吧。
zhangmangui|  楼主 | 2018-10-16 22:15 | 只看该作者
混子黄 发表于 2018-10-16 14:51
支持斑竹,希望在出一个launchxl-f28379d的教程,虽然应该差不多,但是双核应该麻烦很多吧。 ...
恩   多核比较麻烦     现在加班多    没时间啊
学生会那点事ya| | 2018-10-17 20:57 | 只看该作者
张工还没完毕,占用了n多楼层
zhangmangui|  楼主 | 2018-10-17 21:43 | 只看该作者
很好    适用于入门学习
