AVR32的启动过程
1367|0
wenming|  楼主 | 2007-11-19 14:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
U-Boot 1.1.4-at0 (Jan  3 2007 - 10:30:09)
U-Boot code: 00000000 -> 000144f7  data: 24000000 -> 24002d80
SDRAM: 32 MB at address 0x10000000
Testing SDRAM...OK
malloc: Using memory from 0x11fc0000 to 0x12000000
Flash:  8 MB at address 0x00000000
DRAM Configuration:
Bank #0: 10000000 32 MB
In:    serial
Out:   serial
Err:   serial
Net:   macb0, macb1
Press SPACE to abort autoboot in 1 sec
### JFFS2 loading 'uImage' to 0x10200000
Scanning JFFS2 FS: ....... done.
### JFFS2 load complete: 912671 bytes loaded to 0x10200000
## Booting image at 10200000 ...
   Image Name:   Linux-2.6.18-atngw
   Image Type:   AVR32 Linux Kernel Image (gzip compressed)
   Data Size:    912607 Bytes = 891.2 kB
   Load Address: 10000000
   Entry Point:  90000000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting kernel at 90000000 (params at 11fc0040)...
pdc pdc.0: Atmel Peripheral DMA Controller e
EIM: External Interrupt Module at 0xfff00000, IRQ 19
EIM: Handling 4 external IRQs, starting with IRQ 64
smc smc.0: Atmel Static Memory Controller at 0xfff03400
pio0: Atmel Port Multiplexer at 0xffe02800 (irq 13)
pio0: Handling 32 external IRQs, starting with IRQ 96
pio1: Atmel Port Multiplexer at 0xffe02c00 (irq 14)
pio1: Handling 32 external IRQs, starting with IRQ 128
pio2: Atmel Port Multiplexer at 0xffe03000 (irq 15)
pio2: Handling 32 external IRQs, starting with IRQ 160
pio3: Atmel Port Multiplexer at 0xff
pio3: Handling 32 external IRQs, starting with IRQ 192
pio4: Atmel Port Multiplexer at 0xffe03800 (irq 17)
pio4: Handling 32 external IRQs, starting with IRQ 224
dmac0: DesignWare DMA controller at 0xff200000 irq 2
NET: Registered protocol family 2
IP route cache hash table entries: 256 (order: -2, 1024 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 1024 bind 512)
TCP reno registered
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler cfq registered (default)
Serial: Atmel USART3 driver
usart.1: ttyS0 at MMIO 0xffe01000 (irq = 7) is a USART3
loop: loaded (max 8 devices)
eth0: Atmel MACB at 0xfff01800 irq 25 (00:04:25:1c:55:b4)
eth1: Atmel MACB at 0xfff01c00 irq 26 (00:04:25:1c:55:b5)
physmap platform flash device: 00800000 at 00000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
 Amd/Fujitsu Extended Query Table at 0x0041
number of CFI
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using physmap partition information
Creating 3 MTD partitions on "physmap-flash.0":
0x00000000-0x00020000 : "u-boot"
0x00020000-0x007f0000 : "root"
0x007f0000-0x00800000 : "env"
atmel_spi atmel_spi.0: Atmel SPI Controller at 0xffe00000 (irq 3)
mtd_dataflash spi0.0: AT45DB642x (8448 KBytes)
ip_conntrack version 2.4 (256 buckets, 2048 max) - 204 bytes per conn
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP bic registered
NET: Registered protocol family 1
NET: Registered protocol family 17
Time: avr32 clocksource has been installed.
VFS: Mounted root (jffs2 filesystem).
Freeing init memory: 56K (90000000 - 9000e000)
init started:  BusyBox v1.4.2 (2007-04-17 15:34:55 CEST) multi-call binary
 * mounting virtual filesystems: /proc /sys /dev /dev/pts /config /tmp /var/run
/var/lib/samba /var/log
 * set mdev hotplug ...          [ OK ]
 * mdev ...                      [ OK
 * setting hostname ...          'ngw.example.net'
 * network loopback ...          ][ OK ]
 * starting syslogd ...          [ OK ]
 * log messages to syslog ...    [ OK ]
 * starting klogd ...            [ OK ]
 * probing modules ...           vfat loaded, mmc_block loaded, atmel-mci loaded
, [ OK ]
 * mounting filesystems:         /usr
 * setup eth0 ...                [ STATIC ] (10.11.12.1)
 * setup eth1 ...                [ OK ]
 * network ...                   [ OK ]
 * starting telnetd ...          [ OK ]
 * iptables postrouting ...      [ OK ]
 * iptables incoming trafic ...  [ OK ]
 * iptables outgoung trafic ...  [ OK ]
 * starting dnsmasq ...          [ OK ]
 * running ntpdate ...           [ FAILED ]
 * starting dropbear ...         [ OK ]
 * starting inted ...            [ OK ]
 * starting nmbd ...             [ OK ]
 * starting smbd ...             [ OK ]
 * starting winbindd ...         [ OK ]
 * starting httpd ...            [ OK ]
 * get board type for GPIO ...   'NGW'
 * setup GPIO boot LED ...       [ OK ]
 * setup GPIO LED A ...          [ OK ]
 * setup GPIO LED B ...          [ OK ]
Network Gateway ready
BusyBox v1.4.2 (2007-04-17 15:34:55 CEST) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
