[程序源码]
ILI9341芯片驱动程序的问题
2889|10
纪国圣|  楼主 | 2016-3-11 19:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人刚入门stm32不久。最近自己设计了一款stm32最小系统+SD卡+TFT触摸屏。在写3.2寸TFT驱动程序时,参数设置使用了原厂提供的初始化程序,可是屏幕变成背景灰色,有一道一道的纹线,使用原子的驱动程序也出现同样的情况。读取屏幕的ID,可以正确的读到9431。现在卡在这里,不知道怎么办。请各位大神指点迷津。
程序如下:
ILI9341驱动程序:
#include <ILI9341.h>
#include "delay.h"
extern int REK;                        //ID号
void ILI9341_GPIO_config(void)        //引脚配置
        GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable , ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_6|GPIO_Pin_5|GPIO_Pin_4|GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_ResetBits(GPIOA,GPIO_Pin_All);
void LCD_WR_DATA(unsigned int val)        //写数据
        LCD_RS_SET;
        LCD_RD_SET;
        LCD_CS_CLR;
        DATAOUT(val);
        LCD_WR_CLR;
        LCD_WR_SET;
        LCD_CS_SET;
void LCD_WR_REG(unsigned int reg)                //写命令字
        LCD_RS_CLR;//дµØÖ·
        LCD_RD_SET;
        LCD_CS_CLR;
        DATAOUT(reg);
        LCD_WR_CLR;
        LCD_WR_SET;
        LCD_CS_SET;
u16 LCD_RD_DATA(void)        //读数据 使用原子的程序
        u16 t;
        GPIOA->CRL=0X88888888;
        GPIOA->CRH=0X88888888;
        GPIOA->ODR=0X0000;
        LCD_RS_SET;
        LCD_CS_CLR;
        LCD_RD_CLR;
        t=DATAIN;
        LCD_RD_SET;
        LCD_CS_SET;
        GPIOA->CRL=0X33333333;
        GPIOA->CRH=0X33333333;
        GPIOA->ODR=0XFFFF;
        return t;
void LCD_Init(void)                //ILI9341初始化
        ILI9341_GPIO_config();
        LCD_RE_SET;
        delay_ms(100);
        LCD_RE_CLR;
        delay_ms(200);
        LCD_RE_SET;
        delay_ms(300);
        LCD_WR_REG(0xD3);
        LCD_RD_DATA();                                 //dummy read
        LCD_RD_DATA();
        REK=LCD_RD_DATA();
        REK<<=8;
        REK|=LCD_RD_DATA();
LCD_WR_REG(0xCF);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0xC1);
LCD_WR_DATA(0X30);
LCD_WR_REG(0xED);
LCD_WR_DATA(0x64);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0X12);
LCD_WR_DATA(0X81);
LCD_WR_REG(0xE8);
LCD_WR_DATA(0x85);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x79);
LCD_WR_REG(0xCB);
LCD_WR_DATA(0x39);
LCD_WR_DATA(0x2C);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x34);
LCD_WR_DATA(0x02);
LCD_WR_REG(0xF7);
LCD_WR_DATA(0x20);
LCD_WR_REG(0xEA);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_REG(0xC0); //Power control
LCD_WR_DATA(0x1D); //VRH[5:0]
LCD_WR_REG(0xC1); //Power control
LCD_WR_DATA(0x12); //SAP[2:0];BT[3:0]
LCD_WR_REG(0xC5); //VCM control
LCD_WR_DATA(0x33);
LCD_WR_DATA(0x3F);
LCD_WR_REG(0xC7); //VCM control
LCD_WR_DATA(0x92);
LCD_WR_REG(0x3A); // Memory Access Control
LCD_WR_DATA(0x55);
LCD_WR_REG(0x36); // Memory Access Control
LCD_WR_DATA(0x08);
LCD_WR_REG(0xB1);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x12);
LCD_WR_REG(0xB6); // Display Function Control
LCD_WR_DATA(0x0A);
LCD_WR_DATA(0xA2);
LCD_WR_REG(0x44);
LCD_WR_DATA(0x02);
LCD_WR_REG(0xF2); // 3Gamma Function Disable
LCD_WR_DATA(0x00);
LCD_WR_REG(0x26); //Gamma curve selected
LCD_WR_DATA(0x01);
LCD_WR_REG(0xE0); //Set Gamma
LCD_WR_DATA(0x0F);
LCD_WR_DATA(0x22);
LCD_WR_DATA(0x1C);
LCD_WR_DATA(0x1B);
LCD_WR_DATA(0x08);
LCD_WR_DATA(0x0F);
LCD_WR_DATA(0x48);
LCD_WR_DATA(0xB8);
LCD_WR_DATA(0x34);
LCD_WR_DATA(0x05);
LCD_WR_DATA(0x0C);
LCD_WR_DATA(0x09);
LCD_WR_DATA(0x0F);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x00);
LCD_WR_REG(0XE1); //Set Gamma
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x23);
LCD_WR_DATA(0x24);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x38);
LCD_WR_DATA(0x47);
LCD_WR_DATA(0x4B);
LCD_WR_DATA(0x0A);
LCD_WR_DATA(0x13);
LCD_WR_DATA(0x06);
LCD_WR_DATA(0x30);
LCD_WR_DATA(0x38);
LCD_WR_DATA(0x0F);
LCD_WR_REG(0x11); //Exit Sleep
delay_ms(120);
LCD_WR_REG(0x29); //Display on
void LCD_SetArea(unsigned int stx,unsigned int sty,unsigned int endx,unsigned int endy)        //设置窗口
        LCD_WR_REG(0x2A);
//        LCD_WR_DATA((stx>>8)&0x00ff);
//        LCD_WR_DATA(stx&0x00ff);
//        LCD_WR_DATA((endx>>8)&0x00ff);
//        LCD_WR_DATA(endx&0x00ff);
        LCD_WR_DATA(0x00);
        LCD_WR_DATA(0x00);
        LCD_WR_DATA(0x01);
        LCD_WR_DATA(0x3f);
//        LCD_WR_DATAX(stx);
//        LCD_WR_DATAX(endx);
        LCD_WR_REG(0x2B);
//        LCD_WR_DATA((sty>>8)&0x00ff);
//        LCD_WR_DATA(sty&0x00ff);
//        LCD_WR_DATA((endy>>8)&0x00ff);
//        LCD_WR_DATA(endy&0x00ff);
        LCD_WR_DATA(0x00);
        LCD_WR_DATA(0x00);
        LCD_WR_DATA(0x00);
        LCD_WR_DATA(0xef);
//        LCD_WR_DATAX(sty);
//        LCD_WR_DATAX(endy);
void LCD_SetAreaXY(unsigned char x,unsigned int y)
        LCD_SetArea(x,y,x,y);
void LcdWirteColorData(unsigned int color)        //写颜色值至ILI9341
        LCD_RS_SET;
        LCD_RD_SET;
        LCD_CS_CLR;
        DATAOUT(color);
        LCD_WR_CLR;
        LCD_WR_SET;
        LCD_CS_SET;
void LCD_Clear(unsigned int color)        //清屏操作
        unsigned int i,j;
        LCD_SetArea(0,0,239,319);
        LCD_WR_REG(0x2C);
        for(i = 0;i < 320;i++)
                for(j = 0;j < 240;j++)
                        LcdWirteColorData(color);
主函数:
int REK = 0xffff;
int main(void)
                USART3_Config(9600);
                delay_init();
                LCD_Init();
                LCD_Clear(Yellow);
                while(1)
                        printf("ID is :%x\n",REK);
                        LCD_Clear(Yellow);
纪国圣|  楼主 | 2016-3-11 19:49 | 只看该作者
电路图如图所示:
纪国圣|  楼主 | 2016-3-11 20:56 | 只看该作者
新人第一次发帖,别沉呀。
淼淼森森| | 2016-3-11 21:57 | 只看该作者
你好,我也用过ILI9341,请问屏之前用过吗,屏的电路中有个电阻断开就可以了,可以发下屏的资料吗
淼淼森森| | 2016-3-11 22:01 | 只看该作者
要不你看下屏的资料,屏自身的电路有两种连接方式,你换了试下,我当时就是这样解决的,希望能帮到你
纪国圣|  楼主 | 2016-3-11 22:13 | 只看该作者
这个是厂家的产品承认书,还有一份ILI9341的说明书太大,传不上来。
还有,屏上只有电容,没有看到电阻。 SPEC-Z320IT008_v0.3.pdf (535.42 KB)
纪国圣|  楼主 | 2016-3-11 22:21 | 只看该作者
以前用过这个厂家生产的屏,也是ILI9341,不过是37Pin的。当时厂家提供的驱动也是出现这样的问题。后来在参数设置那随便改了几个,居然给我调通了。后来厂家不生产那个屏了,我就换了这个40Pin的屏,现在出现这问题,真心没辙了。
lgq1542380129| | 2016-3-12 09:31 | 只看该作者
读出ID署名FSMC配置的时序没有问题。应该是在写入RAM时,少写
一条指令
纪国圣|  楼主 | 2016-3-12 09:52 | 只看该作者
这款屏的说明书有点怪,在厂家发给我的ILI9341的说明书上居然没有看到有关0xCF,0xED之类的说明。
纪国圣|  楼主 | 2016-3-12 11:30 | 只看该作者
一条指令
关键是我也不知道漏写了哪一条指令,这些参数设置都大同小异的,参照别人的程序也都那样。看手册也看迷糊了,厂家发给我的手册里面居然没有对0xCF等寄存器的描述。
纪国圣|  楼主 | 2016-3-19 12:35 | 只看该作者
千万别沉呀。
