为什么进入LPM3,电流还有20MA
1051|13
自民|  楼主 | 2016-5-14 07:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
通过RTC中断1S唤醒
void main(void)
        WM_Initialize();                // System initialize
        // Display "123456"
  LCD_Display0_8();
  while(1)
        __bis_SR_register(LPM3_bits + GIE);   // 进入 LPM3 w/ interrupt
void WM_Initialize(void)
        WDTCTL = WDTPW + WDTHOLD;          // Stop watchdog
        //        WDTCTL = WDTPW + WDTCNTCL + WDTSSEL0 + WDTIS0 + WDTIS1;  // Set watchdog 16s
        PM5CTL0 &= ~LOCKLPM5;              // Disable the GPIO power-on default high-impedance mode
        // to activate previously configured port settings
        GPIO_Config();              // GPIO initialize
        CLOCK_Config();             // System clock initialize
        LCD_Config();               // LCD module initialize
        RTC_Config();
        //P1SEL0 |= BIT5;  //配置P15为输入脚  20160506
       //          P1REN |= BIT5;
        //P1REN &= ~BIT5; // to be comment  20160506
        //TA0CTL = 0;  20160506
void CLOCK_Config()
        P4SEL0 |= BIT1 + BIT2;                  // Select pin4.1 pin4.2 as crystal function
        do
                CSCTL7 &= ~(XT1OFFG + DCOFFG);            // Clear XT1 and DCO fault flag  清除 XT1 DCO 失效标志
                SFRIFG1 &= ~OFIFG;
        }while (SFRIFG1 & OFIFG);                     // Test oscillator fault flag  如果失效标志存在
        CSCTL4 = SELA__XT1CLK;                                        // IMPORTANT. Select ACLK = XT1 = 32768Hz
void LCD_Config()
        uint8_t ui8Cnt;
        uint8_t *pLCD = (uint8_t *)&LCDM0;
        for (ui8Cnt = 13; ui8Cnt > 0; ui8Cnt--)                        // Clear LCD memory
                *pLCD++ = 0x00;                                        // CLR LCD
        SYSCFG2 |= LCDPCTL;                              // R13/R23/R33/LCDC1/LCDC2 pins selected  设置 LCD功耗
        LCDPCTL0 = 0xFFFF;
        LCDPCTL1 = 0x01FF;                                        //设置 LCD管脚 L0~L24 pins selected
        LCDVCTL = LCDSELVDD + LCDCPEN;                // Mode 2 设置 降低LCD 功耗 片上电荷泵
        LCDCSSEL0 = 0x000F;                                        // 设置 公共极  COM0~3
        LCDCSSEL1 = 0x0000;
  LCDM0 = 0x21;                                              // L0 = COM0, L1 = COM1
  LCDM1 = 0x84;
        LCDCTL0 |= LCD4MUX + LCDLP + LCDON;        // 打开LCD: 4-mux 模式
void RTC_Config()
        RTCCTL = RTCSS__XT1CLK + RTCSR + RTCPS__1 | RTCIE;
        RTCMOD = 32768-1;                             //1s
        tRTCData.ui8Year = 14;              // RTC initialize
        tRTCData.ui8Month = 7;
        tRTCData.ui8Day = 30;
        tRTCData.ui8Hour = 23;
        tRTCData.ui8Minute = 59;
        tRTCData.ui8Second = 55;
自民|  楼主 | 2016-5-14 07:46 | 只看该作者
// RTC interrupt service routine
#pragma vector=RTC_VECTOR
__interrupt void RTC_ISR(void)
        switch(__even_in_range(RTCIV,RTCIV_RTCIF))
        case RTCIV_NONE: break;             // No interrupt
        case RTCIV_RTCIF:                   // RTC Overflow
                uint8_t ui8Days = 31;
                uint8_t *pAddress;               // For monthly data storage
                tRTCData.ui8Second++;
                __low_power_mode_off_on_exit();  //退出中断时唤醒CPU
        break;
        default: break;
dirtwillfly| | 2016-5-14 23:07 | 只看该作者
你是怎么测量的电流?只是msp430的电流吗,还是带着外围电路?
自民|  楼主 | 2016-5-15 07:37 | 只看该作者
测MSP430供电电压VCC上的电流
自民|  楼主 | 2016-5-15 07:39 | 只看该作者
程序有问题吗?
sgq151679| | 2016-5-15 10:53 | 只看该作者
VCC应该还有其他负载吧
baimiaocun2015| | 2016-5-15 16:03 | 只看该作者
这个需要检查下的,LMP3模式下应该在uA级别的。
可可球| | 2016-5-15 22:27 | 只看该作者
进入低功耗模式,要确保外围模块的不工作了,电源处于关闭状态的啊
自民|  楼主 | 2016-5-16 15:27 | 只看该作者
主要原因找到,是I/O口设置问题MSP430FR4133
现在LMP3模式下在80uA
正常吗?
FireRiver9| | 2016-5-16 20:29 | 只看该作者
降到uA级应该就差不多了
自民|  楼主 | 2016-5-27 09:58 | 只看该作者
查出来,外部参考电压,改用内部参考电压,现在功耗是  19UA到7UA跳变
平常只开RTC,1秒钟定时,LPM3,只在外部中断才唤醒。
这样正常吗?
评分
参与人数 1威望 +6 收起 理由
dirtwillfly + 6 赞一个!感谢分享
自民|  楼主 | 2016-5-27 10:30 | 只看该作者
如果RTC关掉只有7UA
dirtwillfly| | 2016-5-27 11:17 | 只看该作者
平常只开RTC,1秒钟定时,LPM3,只 ...
这个正常了,一般就是ua级
有些msp430能到4ua一下
或者进入lpm3.5、lpm4.5,能有零点几ua
xmar| | 2016-5-27 11:28 | 只看该作者
楼主说啥?20MA!,20000000 安培!?写错啦吧。是不是20mA?
