[verilog]
求解释SPI代码,有几点不明白
3322|4
加了颜色的代码什么意思
* SPI MASTER
* January 2007
`timescale 10ns/1ns
module SPI_Master ( miso, mosi, sclk, ss, data_bus, CS, addr, pro_clk, WR, RD);
inout [7:0] data_bus;           // 8 bit bidirectional data bus
input pro_clk;                  // Host Processor clock
input miso;                     // Master in slave out
input [1:0] addr;               // A1 and A0, lower bits of address bus
input CS;                       // Chip Select
input WR, RD;                   // Write and read enables
output mosi;                    // Master out slave in
output sclk;                    // SPI clock
output [7:0] ss;                // 8 slave select lines
reg [7:0] shift_register;        // Shift register
reg [7:0] txdata;                // Transmit buffer
reg [7:0] rxdata;                // Receive buffer
reg [7:0] data_out;              // Data output register
reg [7:0] data_out_en;           // Data output enable
reg [7:0] control, status;       // Control Register COntrols things like ss, CPOL, CPHA, clock divider
                                 // Status Register is a dummy register never used.
reg [7:0] clk_divide;            // Clock divide counter
reg [3:0] count;                 // SPI word length counter
reg sclk;
reg slave_cs;                    // Slave cs flag
reg mosi;                                           // Master out slave in
reg spi_word_send;               // Will send a new spi word.
wire [7:0] data_bus;
wire [7:0] data_in = data_bus;
wire spi_clk_gen;
wire [2:0] divide_factor = control[2:0];
wire CPOL = control[3];
wire CPHA = control[4];
wire [7:0]ss;
/* Slave Select lines */
assign ss[7] = ~( control[7] &  control[6] &  control[5] & (~slave_cs));
assign ss[6] = ~( control[7] &  control[6] & ~control[5] & (~slave_cs));
assign ss[5] = ~( control[7] & ~control[6] &  control[5] & (~slave_cs));
assign ss[4] = ~( control[7] & ~control[6] & ~control[5] & (~slave_cs));
assign ss[3] = ~(~control[7] &  control[6] &  control[5] & (~slave_cs));
assign ss[2] = ~(~control[7] &  control[6] & ~control[5] & (~slave_cs));
assign ss[1] = ~(~control[7] & ~control[6] &  control[5] & (~slave_cs));
assign ss[0] = ~(~control[7] & ~control[6] & ~control[5] & (~slave_cs));
/* clock divide */
assign spi_clk_gen = clk_divide[divide_factor];
/* Clock Divider */
always @ (negedge pro_clk) begin
    clk_divide = clk_divide + 1;
end
/* Reading the miso line and shifting */
always @ (posedge (sclk ^ (CPHA ^ CPOL)) or posedge spi_word_send) begin
    if (spi_word_send) begin
        shift_register[7:0] = txdata;
    end else begin
        shift_register = shift_register << 1;
        shift_register[0] <= miso;
    end
end
/* Writing the mosi */
always @ (negedge (sclk ^ (CPHA ^ CPOL)) or posedge spi_word_send) begin
        mosi = txdata[7];
    end else begin
        mosi = shift_register[7];
    end
end
/* Contolling the interrupt bit in the status bit */
always @ (posedge slave_cs or posedge spi_word_send) begin
        status[0] = 0;
    end else begin
            status = 8'h01;
          rxdata = shift_register;         // updating read buffer
        end
end
/* New SPI wrod starts when the transmit buffer is updated */
always @ (posedge pro_clk) begin
        slave_cs <= 0;
    end else if ((count == 8) & ~(sclk ^ CPOL)) begin
        slave_cs <= 1;
    end
end
/* New Spi word is intiated when transmit buffer is updated */
    if (CS & WR & addr[1] & ~addr[0]) begin
        spi_word_send <=1;
    end else begin
        spi_word_send <=0;
    end
end
/* Generating the SPI clock */
always @ (posedge spi_clk_gen) begin
    if (~slave_cs) begin
        sclk = ~sclk;
    end else if (~CPOL) begin
        sclk = 0;
    end else begin
        sclk = 1;
    end
end
/* Counting SPI word length */
always @ (posedge sclk or posedge slave_cs) begin
    if (slave_cs) begin
        count = 0;
    end else begin
        count = count + 1;
    end
end
/* Reading, writing SPI registers */
    if (CS) begin
        case (addr)
        2'b00 : if (WR) control <= data_in;
        2'b01 : if (RD) data_out <= status;   // Void
                  2'b10 : if (WR) txdata <= data_in;
                  2'b11 : if (RD) data_out <= rxdata;
        endcase
    end
end
/* Controlling the data out enable */
always @ (RD or data_out) begin
    if (RD)
    data_out_en = data_out;
    else
    data_out_en = 8'bz;
end
assign data_bus = data_out_en;
initial
begin
    mosi = 0;
    //sclk = 0;
    control = 0;
    count = 0;
    slave_cs = 1;
    txdata = 0;
    rxdata = 0;
    clk_divide = 0;
    data_out = 0;
end
endmodule
/********************************************** END ******************************************************************/
玄德| | 2016-9-26 11:00 | 只看该作者
SPI有多种时序方式,用户设置CPHA、CPOL两个参数,选择其中一种时序。
红色字体就是实现用户选择的时序。
找个STM32芯片的手册看看。
cyberbill|  楼主 | 2016-9-26 15:48 | 只看该作者
红色字体就是实现用户选择的时序。 ...
关键是我看了手册之后,无法和verilog代码联系起来...
郁闷啊
avkmonkey| | 2016-9-27 23:04 | 只看该作者
首先看此图:
CPOL代表时钟极性, CPHA代表时钟相位,这部分知识请查阅相关资料。
简单地说:
CPOL=0  CPHA=0 上升沿有效,
CPOL=0  CPHA=1 下降沿有效,
CPOL=1  CPHA=0 下降沿有效,
CPOL=1  CPHA=1 上升沿有效,
那么(CPHA ^ CPOL)==1时下降沿有效,(CPHA ^ CPOL)==0时上升降沿有效。
代码中(posedge (sclk ^ (CPHA ^ CPOL)) ,当(CPHA ^ CPOL)==0时上升降沿有效,sclk异或上0还是他自己,然后和前面的posedge结合,刚好是上升沿触发。
当(CPHA ^ CPOL)==1时下降沿有效,sclk异或上1相当于取反,然后和前面的posedge结合,变成了是下降沿触发。
阿甘童鞋| | 2016-10-12 11:11 | 只看该作者
你好,我正在做stm32和fpga进行spi通讯,代码可以发我一份吗
