DSP28335怎么实现错误联防的功能?
2033|0
FCCdsp|  楼主 | 2016-10-24 20:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求教啊,DSP28335怎么实现错误联防的功能?PWM正常输出,当TZ1低电平时强制PWM输出低
#include "DSP2833x_Device.h"    // DSP2833xHeaderfile Include File
#include "DSP2833x_Examples.h"  // DSP2833xExamples Include File
// Prototypestatements for functions found within this file.
interrupt void EPWM1_TZINT_ISR(void);
void InitEPwm1Example();
void main(void)
   InitSysCtrl();
   InitEPwm1Gpio();
EALLOW;
   GpioCtrlRegs.GPAMUX1.bit.GPIO12=0x1;
EDIS;
   DINT;
   InitPieCtrl();
// Disable CPUinterrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   EALLOW; // This isneeded to write to EALLOW protected registers
   PieVectTable.EPWM1_TZINT = &EPWM1_TZINT_ISR;//EPWM1_TZINT_ISR;
   EDIS;   // This isneeded to disable write to EALLOW protected registers
   InitEPwm1Example();
//   InitEPwm2Example();
   IER|=M_INT2;
   PieCtrlRegs.PIEIER2.bit.INTx1=1;
   EINT;  // EnableGlobal interrupt INTM
   ERTM;  // EnableGlobal realtime interrupt DBGM
// Step 6. IDLEloop. Just sit and loop forever (optional):
   for(;;)
       __asm("          NOP");
   EPwm1Regs.TBPRD = 937.5;                        // Set timer period
   EPwm1Regs.TBPHS.half.TBPHS = 0x0000;           // Phase is 0
   EPwm1Regs.TBCTR = 0x0000;                      // Clear counter
   EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up
   EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;        // Disable phase loading
   EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV4;       // Clock ratio to SYSCLKOUT
   EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV4;
   EPwm1Regs.TBCTL.bit.SYNCOSEL=0x01;
   EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;    // Load registers every ZERO
   EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
   EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
   EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
   // Set actions
   EPwm1Regs.AQCTLA.bit.ZRO = 0x2;//AQ_SET;             // Set PWM1A on Zero
   EPwm1Regs.AQCTLA.bit.PRD = 0x1;//AQ_CLEAR;
   // Active Low PWMs - Setup Deadband
   EPwm1Regs.DBCTL.bit.OUT_MODE = 0x3;//DB_FULL_ENABLE;
   EPwm1Regs.DBCTL.bit.POLSEL = 0x2;//DB_ACTV_LO;
   EPwm1Regs.DBCTL.bit.IN_MODE = 0x0;//DBA_ALL;
   EPwm1Regs.DBRED = 30;//EPWM1_MIN_DB;
   EPwm1Regs.DBFED = 30;//EPWM1_MIN_DB;
  // EPwm1_DB_Direction = DB_UP;
   EPwm1Regs.TZSEL.bit.OSHT1=1;
   EPwm1Regs.TZEINT.bit.OST=1;
   // Interrupt where we will change the Deadband
   EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO;     // Select INT on Zero event
   EPwm1Regs.ETSEL.bit.INTEN = 1;                // Enable INT
   EPwm1Regs.ETPS.bit.INTPRD = ET_3RD;           // Generate INT on 3rd event
// Interruptroutines uses in this example:
          EPwm1Regs.TZCTL.bit.TZA=0x2;
          EPwm1Regs.TZCTL.bit.TZB=0x2;
          EPwm1Regs.ETCLR.bit.INT=1;
          PieCtrlRegs.PIEACK.all=PIEACK_GROUP2;
          EPwm1Regs.AQSFRC.all=0xc0;
          EPwm1Regs.AQCSFRC.bit.CSFA=0x1;
          EPwm1Regs.AQCSFRC.bit.CSFB=0x1;
      asm ("      ESTOP0");
      for(;;);
