请教大家一个6678的问题
971|1
qaz098xsw|  楼主 | 2016-10-24 21:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TE, TI, ST, IO, ck
Prototype    : lock_mem_prot_regs
Description  : lock memory protection registers
Input        : None
Output       : None
Return Value :
   History        :
   1.Date         : 2010/12/12
     Author       : Brighton Feng
     Modification : Created function
#pragma CODE_SECTION (lock_mem_prot_regs, ".text:Core_MPAX")
void lock_mem_prot_regs()
         int i;
         /*1. Write a 1 to the KEYR field of the MPLKCMD register. This resets some internal
         status for the MPLK0 through MPLK3 registers.*/
         gpCGEM_regs->MPLKCMD = (1<<CSL_CGEM_MPLKCMD_KEYR_SHIFT);
         /*2. Write the key to MPLK0 through MPLK3. All four registers must be written
         exactly once. They may be written in any order.*/
         for(i=0; i<4; i++)
                 gpCGEM_regs->MPLK
= mem_prot_key;
         /*3. Write a 1 to the LOCK field of the MPLKCMD register. This engages the lock.*/
         gpCGEM_regs->MPLKCMD = (1<<CSL_CGEM_MPLKCMD_LOCK_SHIFT);
         /*wait to make sure it is locked*/
         while(0==(gpCGEM_regs->MPLKSTAT&CSL_CGEM_MPLKSTAT_LK_MASK));
TI原厂的6678开发板,每次启动仿真运行到KeyStone_common_CPU_init()中 while(0==(gpCGEM_regs->MPLKSTAT&CSL_CGEM_MPLKSTAT_LK_MASK));这个地方时就在这里死循环了,请教各位大侠,如何解决这个问题,在下感谢了。
enginezhong| | 2016-10-25 20:50 | 只看该作者
还是程序的问题吧,可以烧官方的例程看看,还是这个问题吗?
