求助技术手册的翻译,这一段没懂啊。
296|2
pcc120421408|  楼主 | 2016-11-17 13:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, ge, ic, AN, se
Applications in which the correct CPU operating frequency is absolutely critical should
implement a mechanism by which the DSP will be held in reset should the input clocks ever
fail. For example, an R-C circuit may be used to trigger the XRS pin of the DSP should the
capacitor ever get fully charged. An I/O pin may be used to discharge the capacitor on a
periodic basis to prevent it from getting fully charged. Such a circuit would also help in
detecting failure of the flash memory and the V DD3VFL rail.
zhangmangui| | 2016-11-17 22:47 | 只看该作者
没看懂  不知道RC用到哪儿了
