关于xilinx FPGA的时序仿真问题
771|0
 楼主| 李大家 发表于 2017-4-11 09:51 | 显示全部楼层 |阅读模式
这是主程序module test1(
   input wire clk,
        input wire rst,
        input wire [7:0] in,
        //output reg [3:0] cnt,
        output reg [7:0] out
always @ (posedge clk or negedge rst)
begin
    if(!rst)
    begin
         out <= 0;
         end
         else
         begin
              out <= in;
      end
end
这是仿真tb
      // Generate the stimulate
      initial begin
                        clk = 1'b0;
               rst = 1'b0;
               in = 8'h00;
          #40; rst = 1'b1;
          #20; in = 8'b00001111;
              #20; in = 8'h55;
              #20; in = 8'h23;
               #20; in = 8'h96;
         #1000; $finish();
       end
always
begin
       #10 clk =~clk;
end
下面是仿真后的道德波形?为什么没有赋值过去呢?
