RGB LED Signal Tower With Wi-Fi® Interface Reference Design
908|2
dirtwillfly|  楼主 | 2017-4-11 20:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Description
The objective of the TIDA-00994 reference design is to develop an embedded firmware of a multi-segment RGB signal tower used in factory floor and industrial process automation of greater complexity. A Wi-Fi ® interface is implemented to control the stack light and read back status information. The CC3200 SimpleLink™ Wi-Fi®  offers a Wi-Fi access point as  well as an embedded web server for reading status information and controlling the stack light.
Features
  • Flexible and easy-to-control RGB LED tower light design
  • Different switchable modes: demo, temperature, humidity, and stack light
  • Controllable through wi-fi interface
  • One to five RGB LED segments with four individual channels each
  • Adjustable maximum LED current up to 60 mA per channel
dirtwillfly|  楼主 | 2017-4-11 20:13 | 只看该作者
RGB LED Signal Tower WIth Wi-Fi Interface Reference Design.pdf (2.27 MB)
dirtwillfly|  楼主 | 2017-4-11 20:19 | 只看该作者
TIDA-00979 LED Schematics and Block Diagram.pdf (538.82 KB)
TIDA-00979 PWR Schematic and Block Diagram.pdf (830.76 KB)
TIDA-00979 LED BOM.pdf (60.55 KB)
TIDA-00979 PWR BOM.pdf (73.81 KB)
TIDA-00979 LED Assembly Drawing.pdf (181.79 KB)
TIDA-00979 PWR Assembly Drawing.pdf (369.02 KB)
TIDA-00979 LED PCB Layer Plots.pdf (700.42 KB)
TIDA-00979 PWR PCB Layer Plots.pdf (1.68 MB)
TIDA-00979 LED CAD Files.zip (358.64 KB)
TIDA-00979 PWR CAD Files.zip (1.03 MB)
TIDA-00979 LED Gerber.zip (342.87 KB)
TIDA-00979 PWR Gerber.zip (496.35 KB)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1193
