[技术问答] 关于Mini58的片内晶振使用问题。
2231|6
 楼主| yyglucky 发表于 2017-7-9 16:00 | 显示全部楼层 |阅读模式
我是一个菜鸟,现在用Mini58做个小项目,哪位大神指点一下,把下面那个用外部晶振改成内部用内部22.1842M的晶振。谢谢
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set P5 multi-function pins for XTAL1 and XTAL2 */
    SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
    SYS->P5_MFP |= (SYS_MFP_P50_XT1_IN | SYS_MFP_P51_XT1_OUT);
    /* Init System Clock        */
    /* Enable external 12MHz XTAL, HIRC */
    CLK->PWRCTL |= CLK_PWRCTL_XTL12M | CLK_PWRCTL_HIRCEN_Msk;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_XTLSTB_Msk | CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to XTL */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_XTAL,CLK_CLKDIV_HCLK(1));
    /* STCLK to XTL STCLK to XTL */
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_XTAL);
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART0_MODULE,CLK_CLKSEL1_UARTSEL_XTAL,CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P1 multi-function pins for UART RXD, TXD */
    SYS->P1_MFP = SYS_MFP_P12_UART0_RXD | SYS_MFP_P13_UART0_TXD;
    /* Set P3 multi-function pins for Clock Output */
    SYS->P3_MFP = SYS_MFP_P36_CLKO;
    /* To update the variable SystemCoreClock */
    SystemCoreClockUpdate();
    /* Lock protected registers */
    SYS_LockReg();
 楼主| yyglucky 发表于 2017-7-9 16:02 | 显示全部楼层
我用的是keil MDK5.23的软件,把系统初始化给改一下,改成内部晶振,谢谢大师。
捉虫天师 发表于 2017-7-9 21:26 | 显示全部楼层
看着手册把对应的项目修改成HIRC。
捉虫天师 发表于 2017-7-9 21:27 | 显示全部楼层
  1. void SYS_Init(void)
  3.     /*---------------------------------------------------------------------------------------------------------*/
  4.     /* Init System Clock        */
  5.     /*---------------------------------------------------------------------------------------------------------*/
  6.     /* Enable Internal RC 22.1184MHz clock */
  7.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  8.     /* Waiting for Internal RC clock ready */
  9.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  10.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  11.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  12.     /* Enable external XTAL 12MHz clock */
  13.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  14.     /* Waiting for external XTAL clock ready */
  15.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  16.     /* Set core clock as PLL_CLOCK from PLL */
  17.     CLK_SetCoreClock(PLL_CLOCK);
  18.     /* Enable UART module clock */
  19.     CLK_EnableModuleClock(UART0_MODULE);
  20.     /* Select UART module clock source */
  21.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
  22.     /*---------------------------------------------------------------------------------------------------------*/
  23.     /* Init I/O Multi-function        */
  24.     /*---------------------------------------------------------------------------------------------------------*/
  25.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  26.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  27.     SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
  28. }
捉虫天师 发表于 2017-7-9 21:28 | 显示全部楼层
上面是官方的例子中的一部分,你可以看看,官方的例子基本上都是使用的内部的这个RC振荡器。
 楼主| yyglucky 发表于 2017-7-10 10:31 | 显示全部楼层
谢谢  天师。
为何我用
    void SYS_Init(void)
有很多变量通不过
 楼主| yyglucky 发表于 2017-7-10 10:32 | 显示全部楼层
我cpu用的mini58    Keil Mdk 5.23
