[技术问答] 新唐的n76e003的iic代码的理解
5743|6
 楼主| qwe12377yu 发表于 2017-7-24 18:09 | 显示全部楼层 |阅读模式
我想请问这个从机发送接收代码是怎么实现的
/* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved.                                         */
//  File Function: N76E003 I2C Slave demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
//  N76E885-series I2C slave mode demo code, the Slave address = 0xA4
//   ____________            _____________
//  |            |   SDA    |             |
//  |N76E003(M) |          | N76E003(S) |
//  |(I2C_Master)|          | (I2C_Slave) |
//  |            |   SCL    |             |
//  |____________|          |_____________|
//  The protocol of I2C is same the "24LC64"
#define I2C_CLOCK               13
#define EEPROM_SLA              0xA4
UINT8 data_received[34], data_num = 0;
void I2C_ISR(void) interrupt 6
    switch (I2STAT)
        case 0x00:
            STO = 1;
            break;
        case 0x60:
            AA = 1;
            //P3 = 0x60;
            break;
        case 0x68:
                                                P02 = 0;
            while(1);
            break;
        case 0x80:
            //P3 = 0x80;
            data_received[data_num] = I2DAT;
            data_num++;
            if (data_num == 34)
                AA = 0;
            else
                AA = 1;
            break;
        case 0x88:
            //P3 = 0x88;
            data_num = 0;
            AA = 1;
            break;
        case 0xA0:
            //P3 = 0xA0;
            AA = 1;
            break;
        case 0xA8:
            //P3 = 0xA0;
            I2DAT = data_received[data_num];
            data_num++;
            AA = 1;
            break;
        case 0xB8:
            //P3 = 0xB8;
            data_num++;
            AA = 1;
            break;
        case 0xC0:
            AA = 1;
            break;
        case 0xC8:
            //P3 = 0xC8;
            AA = 1;
            break;
    SI = 0;
    while(STO);
void Init_I2C(void)
    P13_Quasi_Mode;                         //set SCL (P13) is Quasi mode
    P14_Quasi_Mode;                         //set SDA (P14) is Quasi mode
    SDA = 1;                                //set SDA and SCL pins high
    SCL = 1;
    set_P0SR_6;                             //set SCL (P06) is  Schmitt triggered input select.
    set_EI2C;                               //enable I2C interrupt by setting IE1 bit 0
    set_EA;
    I2ADDR = EEPROM_SLA;                    //define own slave address
    set_I2CEN;                              //enable I2C circuit
    set_AA;
void main(void)
    Set_All_GPIO_Quasi_Mode;
    /* Initial I2C function */
    Init_I2C();                                 //initial I2C circuit
    while (1);
643757107 发表于 2017-7-24 19:29 | 显示全部楼层
全在中断里实现了。
wahahaheihei 发表于 2017-7-24 19:46 | 显示全部楼层
只看到了接收代码。
a_ziliu 发表于 2017-7-24 22:07 | 显示全部楼层
在規格書中,i2c章,有收發的狀態圖
xixi2017 发表于 2017-7-26 10:28 | 显示全部楼层
这个两个实现的,一个是接收,毒I2DAT 就是接收
写I2DAT就是发送。
nannan1218 发表于 2019-1-13 11:04 | 显示全部楼层
楼主,请问主机发送和主机接受那一块代码你理解嘛    这个通信功能你实现了吗   为啥我这边把这个程序load进去   不行啊
antusheng 发表于 2019-1-14 18:13 | 显示全部楼层
先了解IIC的协议,再来看就容易了。
