LINUX 下获取IP地址、MAC地址和广播地址、子网掩码等信息
486|0
Roses|  楼主 | 2017-10-6 12:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在linux 下面通过C语言来获取 平台的 ip、mac、boardcast addr 、 network mask等信息;
建立 socket 网络接口,通过ioctl 来获取 网络参数信息。
参考代码如下:
  •   Copyright (C) 2015 xubinbin 徐彬彬 (Beijing China)
  •   filename: get_ip_info.c
  •   version : v1.1.0
  •   time    : 2015/07/14 10:20
  •   author  : xubinbin ( ternence.hsu@foxmail.com )
  •   root@ubuntu-virtual-machine:# uname -a
  •     Linux ubuntu-virtual-machine 3.13.0-34-generic #60-Ubuntu SMP Wed Aug 13 15:49:09 UTC 2014 i686 i686 i686 GNU/Linux
  • #include <stdio.h>
  • #include <unistd.h>
  • #include <sys/types.h>
  • #include <sys/param.h>
  • #include <sys/ioctl.h>
  • #include <sys/socket.h>
  • #include <net/if.h>
  • #include <netinet/in.h>
  • #include <net/if_arp.h>
  • #define MAX_INTERFACES                  (3)        // max interfaces
  • int  main(int argc, char **argv)
  •     int fd, intrface, ret = 0;
  •     struct ifreq buf[MAX_INTERFACES]; /* ifreq   Array of structures */
  •     struct ifconf ifc;
  •     if ((fd = socket (AF_INET, SOCK_DGRAM, 0)) >= 0)
  •         ifc.ifc_len = sizeof buf;
  •         ifc.ifc_buf = (caddr_t) buf;
  •         if (!ioctl (fd, SIOCGIFCONF, (char *) &ifc))
  •             //get the number of interfaces information
  •             intrface = ifc.ifc_len / sizeof (struct ifreq);
  •             printf("interface num is intrface=%d\n",intrface);
  •             puts("");
  •             //get Device IP and MAC address based interface information circular
  •             while ( (intrface--) > 0)
  •                 //get the device name
  •                 printf ("net device %s\n", buf[intrface].ifr_name);
  •                 //Determine the type of network card
  •                 if (!(ioctl (fd, SIOCGIFFLAGS, (char *) &buf[intrface])))
  •                     if (buf[intrface].ifr_flags & IFF_PROMISC)
  •                         printf("the interface is PROMISC\n");
  •                         ret++;
  •                 else
  •                     char str[256];
  •                     sprintf (str, "cpm: ioctl device %s", buf[intrface].ifr_name);
  •                     perror (str);
  •                 //determine NIC status
  •                 if (buf[intrface].ifr_flags & IFF_UP)
  •                     printf("the interface status is up\n");
  •                 else
  •                     printf("the interface status is down\n");
  •                 //get the current NIC IP address
  •                 if (!(ioctl (fd, SIOCGIFADDR, (char *) &buf[intrface])))
  •                     printf("IP address is:\t");
  •                     printf("%s\n",(char *)inet_ntoa(((struct sockaddr_in*)(&buf[intrface].ifr_addr))->sin_addr));
  •                 else
  •                     char str[256];
  •                     perror (str);
  •                 /* this section can't get Hardware Address,I don't know whether the reason is module driver*/
  •                 if (!(ioctl (fd, SIOCGIFHWADDR, (char *) &buf[intrface])))
  •                     printf("HW address is:\t");
  •                     printf("%02x:%02x:%02x:%02x:%02x:%02x\n",
  •                     (unsigned char)buf[intrface].ifr_hwaddr.sa_data[0],
  •                     (unsigned char)buf[intrface].ifr_hwaddr.sa_data[1],
  •                     (unsigned char)buf[intrface].ifr_hwaddr.sa_data[2],
  •                     (unsigned char)buf[intrface].ifr_hwaddr.sa_data[3],
  •                     (unsigned char)buf[intrface].ifr_hwaddr.sa_data[4],
  •                     (unsigned char)buf[intrface].ifr_hwaddr.sa_data[5]);
  •                 else
  •                     char str[256];
  •                     perror (str);
  •                 //sub network mask
  •                 if (!(ioctl(fd, SIOCGIFNETMASK, (char *) &buf[intrface])))
  •                     printf("NETWORK MASK :\t%s",(char*)inet_ntoa(((struct sockaddr_in*) (&buf[intrface].ifr_addr))->sin_addr));
  •                     puts("");
  •                 else
  •                     char str[256];
  •                     sprintf(str, "SIOCGIFADDR ioctl %s", buf[intrface].ifr_name);
  •                     perror(str);
  •                 //broadcast address
  •                 if (!(ioctl(fd, SIOCGIFBRDADDR, (char *) &buf[intrface])))
  •                     printf("Broadcast Address:\t%s\n",(char*)inet_ntoa(((struct sockaddr_in*) (&buf[intrface].ifr_addr))->sin_addr));
  •                 puts("");
  •         }else
  •         perror ("cpm: ioctl");
  •     }else
  •     perror ("cpm: socket");
  •   close (fd);
  •   return ret;
复制代码
调试效果如下:
