ads1247 问题
917|2
TRUE_ARM|  楼主 | 2011-4-25 18:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
读ADS1247 ,程序如下,结果全是0,
不知道为什么?
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;   // CPOL = 0, SCK 为高有效
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; // CPHA = 1, 数据在SCK 的第一个时钟沿采样
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  //SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;      //15/8
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;  //15M/64=0.23435
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; // LSBF = 0, SPI 数据传输MSB (位7)在先
  SPI_InitStructure.SPI_CRCPolynomial = 7;
void ReadAllRegister(void)
  volatile BYTE Tt;
  volatile BYTE i;
  ENABLESPI_CS();
  ENABLESPI_CS();      //tcssc >= 6ns
  Delay_1_96us();
  //read from 0 to 0x0e
  SPI_SendByte(0xff);
  SPI_SendByte(0x20);
  SPI_SendByte(15-1);
  for(i=0;i<15;i++)
    Tt=SPI_SendByte(0xff);  //nop
   printf("register=%1d,value=%1d.\n",i,Tt);
    Delay_1_96us();
  DISABLESPI_CS();
  DISABLESPI_CS();
BYTE SPI_SendByte(BYTE byt)
  /* Loop while DR register in not emplty */
  while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE)==RESET);
  /* Send byte through the SPI1 peripheral */
  SPI_I2S_SendData(SPI2, byt);
  /* Wait to receive a byte */
  while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
  /* Return the byte read from the SPI bus */
  return SPI_I2S_ReceiveData(SPI2);
TRUE_ARM|  楼主 | 2011-4-25 20:40 | 只看该作者
郁闷,原来是波特率太快了的原因
huzixian| | 2011-4-26 22:11 | 只看该作者
波特率如何选择才能合适呀?
