Battery Tester Reference Design for High Current Applications
537|5
dirtwillfly|  楼主 | 2018-6-23 16:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
Li-Ion battery formation and electrical testing require accurate voltage and current control, usually to better than ±0.05% over the specified temperature range.  This reference design proposes a solution for high-current (up to 50 A) battery tester applications supporting input (bus) voltages from 8 V–16 V and output load (battery) voltages from 0V–5V. The design utilizes an integrated multi-phase bidirectional controller, LM5170, combined with a high precisiondata converters and instrumentation amplifiers to achieve charge and discharge accuracies of 0.01% full scale. To maximize battery capacity and minimize battery formation time, the design uses highly-accurate constant current (CC) and constant voltage (CV) calibration loops with a simplified interface. All key design theories are described guiding users through the part selection process and optimization. Finally, schematic, board layout, hardware testing, and results are also presented.
特性
  • Battery test subsystem with calibration control achieving 0.01% full scale current control accuracy
  • Supports up to 50-A applications with an input voltage (bus) from 8 V–16 V and output load (battery) from 0 V–4.5 V (5 V max)
  • LM5170 bidirectional buck, boost controller
  • Programmable high-precision reference supplied by DAC80004
  • Voltage and current monitoring provided by the ADS131A04 24 bit delta-sigma
  • User friendly control interface
dirtwillfly|  楼主 | 2018-6-23 16:24 | 只看该作者
用户指南
Battery Tester Reference Design for High Current Applications.pdf (3.89 MB)
dirtwillfly|  楼主 | 2018-6-23 16:27 | 只看该作者
TIDA-01040 Schematic and Block Diagram.pdf (1.23 MB)
TIDA-01040 BOM.pdf (215.34 KB)
TIDA-01040 Assembly Drawing.pdf (431.33 KB)
TIDA-01040 PCB.pdf (5.69 MB)
TIDA-01040 CAD Files.zip (4.08 MB)
TIDA-01040 Gerber.zip (1.32 MB)
设计套件与评估模块
USB2ANY 接口适配器
dirtwillfly|  楼主 | 2018-6-23 16:28 | 只看该作者
vivilzb1985| | 2018-6-26 23:06 | 只看该作者
大电流的电池供电监测机制的资料,先温习下的再说
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
