往DSP下载程序问题
1620|4
[Start: Texas Instruments XDS100v2 USB Debug Probe]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\ziyi\AppData\Local\TEXASI~1\CCS\
    ti\2\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusb.dll'.
The library build date was 'Jul 27 2016'.
The library build time was '18:31:37'.
The library package version is '6.0.407.3'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-180' (0xffffff4c).
The title is 'SC_ERR_CTL_NO_TRG_POWER'.
The explanation is:
The controller has detected a target power loss.
The user must turn-on or connect the power supply for the target.
[End: Texas Instruments XDS100v2 USB Debug Probe]
你几我上半打|  楼主 | 2018-8-3 21:15 | 只看该作者
今天下载程序的时候,程序出现这样的问题。请问各位这是什么原因。
zhangmangui| | 2018-8-3 23:07 | 只看该作者
有人说是驱动的问题      还有就是板上拨码开关等是否有改变
free_稀饭| | 2018-8-4 22:25 | 只看该作者
可能原因:
1.DSP供电问题;
2.地线的干扰
坏坏62| | 2018-8-6 10:20 | 只看该作者
我也遇到过类似的问题,一般出现这种问题的原因可能就是信号的干扰,我采取的办法就是换了一个USB口。
