[产品供应]
LT2911R和LT9211规格书
1393|1
Tel18105995017|  楼主 | 2018-9-4 19:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AN, TE, ip, pi, MIPI
目前根据我个人在市场上了解,已经很多MIPI接口屏流入非消费类行业会涉及到行业接口LVDS/RGB转MIPI需求,并且大家也会了解到MIPI屏一般是竖屏,所以涉及到信号转换后带旋转功能产品,(RGB/LVDS转MIPI并且支持旋转90°或270°)这时就需要LT2911R芯片去设计。相反另外就是消费类方案商会涉及到用RGB/LVDS接口屏,所以需要MIPI转RGB/LVDS并旋转90°或180°,LT9211R。总之,目前已经是已经拥有MIPI,RGB,LVDS互转并且旋转90°或180°产品
LT2911R简介1. Description
The Lontium LT2911R is a high performance Dual-Port LVDS to MIPIDSI/CSI-2 bridge chip with Video Rotation between AP and mobile display panel or camera.
The LT2911R can be configured as single-port or dual-port with optional De-SSC function. The bridge deserializes input LVDS data, decodes packets, rotates video, and converts the formatted video data stream to MIPI DSI/CSI-2 transmitter output.
For MIPI DSI/CSI-2 output, the LT2911R features a single port MIPI DSI or CSI-2 transmitter with 1 high-speed clock lane and 1~4 configurable high-speed data lanes operating at maximum 1.8Gb/s/lane, which can support a total bandwidth of up to 7.2Gb/s. LT2911R supports both Non-Burst and Burst DSI/CSI data transferring, as well as Command Mode through Lane-0. And also, the LT2911R can be configured as two port simultaneous display mode.
The LT2911R is fabricated in advanced CMOS process and implemented in 14mm x 14mm QFN128 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• Dual-Port LVDS Receiver
• MIPI Transmitter
• DDR3 Controller
• Miscellaneous
3. Applications
• Mobile systems
• Cellular handsets
• Digital still cameras
• Tablet PC, Notebook PC
• Car Display and Camera System
LT9211R简介
1. Description
The Lontium LT9211 is a high performance convertor which interconvertible between MIPI DSI/CSI-2/Dual-Port LVDS and TTL except for TTL to TTL. The LT9211 deserializes input MIPI/LVDS/TTL video data, decodes packets, and converts the formatted video data stream to MIPI/LVDS/TTL transmitter output between AP and mobile display panel or camera.
The LT9211 can be used as 2-Port MIPI/LVDS Repeater which support maximum 14dB input equalization and programmable pre-emphasis to improve performance.
The LT9211 can also be used as MIPI/LVDS Muxer andSplitter.
The LT9211 is fabricated in advanced CMOS process and implemented in 7.5x7.5mm QFN64 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• Dual-Port LVDS Transimitter
• MIPI Transmitter
• TTL Output
• TTL Intput
• Single-Port MIPI Receiver
• Miscellaneous
3. Applications
• Mobile systems
• Cellular handsets
• Digital  video cameras
如有疑异或需详细讨论其具体方案细节可留言或电话沟通,尽我所能为您解答疑问。
如果需要技术资料,请联系:游生18105995017 QQ:2840038952 价格美丽
更多操作
melocao| | 2018-9-4 19:55 | 只看该作者
需要更好的支持请电联曹生15879296669/QQ2050387502
