[应用相关] STM32使用HAL库操作GPIO(转载)
3271|11
 楼主| 磨砂 发表于 2018-11-13 12:00 | 显示全部楼层 |阅读模式
一  初始化GPIO
使用HAL库的优点在于不用手动添加初始化的代码了,CubeMX会根据软件设置自动生成。
自动生成的HAL库GPIO初始化代码:
static void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_SET);
  /*Configure GPIO pin : PD11 */
  GPIO_InitStruct.Pin = GPIO_PIN_11;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : PD12 PD13 PD14 PD15 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
顺序:(1)定义结构体变量。(2)使能时钟。(3)配置初始化电平。(4)通过结构体变量初始化GPIO。
 楼主| 磨砂 发表于 2018-11-13 12:01 | 显示全部楼层
1.首先定义一个结构体变量GPIO_InitStruct,该变量类型是GPIO_InitTypeDef。
GPIO_InitTypeDef 定义如下:
  * @brief GPIO Init structure definition
typedef struct
  uint32_t Pin;       /*!< Specifies the GPIO pins to be configured.
                           This parameter can be any value of @ref GPIO_pins_define */
  uint32_t Mode;      /*!< Specifies the operating mode for the selected pins.
                           This parameter can be a value of @ref GPIO_mode_define */
  uint32_t Pull;      /*!< Specifies the Pull-up or Pull-Down activation for the selected pins.
                           This parameter can be a value of @ref GPIO_pull_define */
  uint32_t Speed;     /*!< Specifies the speed for the selected pins.
                           This parameter can be a value of @ref GPIO_speed_define */
  uint32_t Alternate;  /*!< Peripheral to be connected to the selected pins.
                            This parameter can be a value of @ref GPIO_Alternate_function_selection */
}GPIO_InitTypeDef;
作用是:设置要用的是哪个引脚、引脚工作模式、上拉还是下拉、速度、XX这个还不知道是干嘛的XX。
 楼主| 磨砂 发表于 2018-11-13 12:02 | 显示全部楼层
2.使能时钟。
  /* GPIO Ports Clock Enable */  __HAL_RCC_GPIOH_CLK_ENABLE();  __HAL_RCC_GPIOD_CLK_ENABLE();
这里使能时钟的方法与标准库不一样,HAL库其实是宏定义,标准库则是函数。
宏定义(使能H口的宏定义):
#define __HAL_RCC_GPIOH_CLK_ENABLE()  do { \
                                        __IO uint32_t tmpreg = 0x00U; \
                                        SET_BIT(RCC->AHB1ENR, RCC_AHB1ENR_GPIOHEN);\
                                        /* Delay after an RCC peripheral clock enabling */ \
                                        tmpreg = READ_BIT(RCC->AHB1ENR, RCC_AHB1ENR_GPIOHEN);\
                                        UNUSED(tmpreg); \
                                         } while(0U)
这里使能H口是因为H口接的外部晶振。
 楼主| 磨砂 发表于 2018-11-13 12:03 | 显示全部楼层
3.配置引脚的初始化电平。
  /*Configure GPIO pin Output Level */  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_SET);
这里设置D口的pin12、pin13、pin14、pin15为高电平。如果最后一个参数是GPIO_PIN_RESET则为低电平。
4.通过结构体变量配置具体的引脚。
PD11为输入,上拉。PD12-15为推挽输出。所以分开配置。
总结一下:(1)定义结构体变量。(2)使能时钟。(3)配置初始化电平。(4)通过结构体变量初始化GPIO。
其中,(3)和(4)可调换顺序
 楼主| 磨砂 发表于 2018-11-13 12:04 | 显示全部楼层
二  功能解释
1.系统分析。
STM32F4Discovery的PD12-15的四个引脚是LED。
我们要做的功能是按键一次点亮一个LED(顺时针PIN12-15,从PIN12开始)并关闭上一个LED。
首先我们需要一个标志变量来代表当前正在亮的LED:
int LEDNUM_Flag = 12;
流程:按键扫描  ->  读到Pin11按下  ->  关闭当前LEDNUM_Flag代表的LED(正在亮的)  ->  LEDNUM_Flag+1  ->  点亮当前LEDNUM_Flag代表的LED;
2.按键输入。
_Bool GetPress(void)
    if(HAL_GPIO_ReadPin(GPIOD,GPIO_PIN_11)==0)
        HAL_Delay(10);//防抖
                while(HAL_GPIO_ReadPin(GPIOD,GPIO_PIN_11)==0)//等待按键抬起。
                return 1;
            else return 0;
    else    return 0;
3.点亮LED。
void TurnOnLED(int flag)
    switch(flag)
        case 12 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12, GPIO_PIN_SET);
            break;
        case 13 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_13, GPIO_PIN_SET);
            break;
        case 14 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_14, GPIO_PIN_SET);
            break;
        case 15 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_15, GPIO_PIN_SET);
            break;
 楼主| 磨砂 发表于 2018-11-13 12:05 | 显示全部楼层
4.关闭LED。
void TurnOffLED(int flag)
    switch(flag)
        case 12 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12, GPIO_PIN_RESET);
            break;
        case 13 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_13, GPIO_PIN_RESET);
            break;
        case 14 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_14, GPIO_PIN_RESET);
            break;
        case 15 :
            HAL_GPIO_WritePin(GPIOD, GPIO_PIN_15, GPIO_PIN_RESET);
            break;
 楼主| 磨砂 发表于 2018-11-13 12:06 | 显示全部楼层
5.标志变量自加。
void FlagPlus(int *flag)
    (*flag)++;
    if((*flag)==16)
        (*flag)=12;
这里一定要用指针,因为函数参数是值传递所以只能用指针来改变LEDNUM_Flag。
6.整合代码。
#include "main.h"
#include "stm32f4xx_hal.h"
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
_Bool GetPress(void);
void TurnOnLED(int flag);
void TurnOffLED(int flag);
void FlagPlus(int *flag);
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  //最开始先点亮PD12的LED
  while (1)
    //有按键按下
    if(GetPress()==1)
            TurnOffLED(LEDNUM_Flag);
            FlagPlus(&LEDNUM_Flag);
            TurnOnLED(LEDNUM_Flag);
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
        HAL_Delay(10);
                return 1;
            else return 0;
    else    return 0;
    switch(flag)
        case 12 :
            break;
        case 13 :
            break;
        case 14 :
            break;
        case 15 :
            break;
    switch(flag)
        case 12 :
            break;
        case 13 :
            break;
        case 14 :
            break;
        case 15 :
            break;
    (*flag)++;
    if((*flag)==16)
        (*flag)=12;
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
void _Error_Handler(char * file, int line)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
 楼主| 磨砂 发表于 2018-11-13 12:07 | 显示全部楼层
三  重要的API。
//IO口使能,  注意这里是D口
//设置推挽输出的IO口输出电平为低
//设置推挽输出的IO口输出电平为高
//初始化一个IO口为输入
//初始化IO为推挽输出
//读取一个输入IO口的电平
HAL_GPIO_ReadPin(GPIOD,GPIO_PIN_11);
