[技术问题解答]
illegal use of 'pragma CODE_SEG/DATA_SEG/CONST_SEG. Two segments with differe...
518|0
code, ST, se, AN, CAN
illegal use of 'pragma CODE_SEG/DATA_SEG/CONST_SEG. Two segments with different types have the same name
出错的位置:
#pragma CODE_SEG __NEAR_SEG NON_BANKED
__interrupt void CAN1_InterruptError(void);
#pragma CODE_SEG CAN1_CODE
ISR(CAN1_InterruptError)
  byte Status = CAN0R**;              /* Read the status register */
  if((Status & CAN_STATUS_BOFF_MASK) == CAN_STATUS_BOFF_MASK) { /* Bus-Off state */
    ErrFlag |= CAN_STATUS_BOFF_EXT_MASK;
    ErrFlag |= (Status & 0x83U);       /* Add error flags */
  else {
    ErrFlag |= (Status & 0xBFU);       /* Add error flags */
  CAN0R** = 0xFEU;                    /* Reset error flags */
  if ((Status & CAN_STATUS_BOFF_MASK) == CAN_STATUS_BOFF_MASK) { /* Is busoff error detected? */
    CAN1_OnBusOff();                   /* If yes then invoke user event */
  } else {
上面中中断函数的声明和定义都对应的同一个段,为什么还会报错!
而且上面这些都是PE自动生成的!为啥还会报错!
问题
问题
