[DemoCode下载] M051的I2C操作
1252|15
 楼主| yiy 发表于 2019-4-14 22:45 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 5 $
  5. * $Date: 14/01/28 11:44a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series I2C Driver Sample Code (Master)
  7. *
  8. * @note
  9. * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M051Series.h"
  14. #define PLLCON_SETTING      SYSCLK_PLLCON_50MHz_XTAL
  15. #define PLL_CLOCK           50000000
  16. /*---------------------------------------------------------------------------------------------------------*/
  17. /* Global variables        */
  18. /*---------------------------------------------------------------------------------------------------------*/
  19. volatile uint8_t g_u8DeviceAddr;
  20. volatile uint8_t g_au8TxData[3];
  21. volatile uint8_t g_u8RxData;
  22. volatile uint8_t g_u8DataLen;
  23. volatile uint8_t g_u8EndFlag = 0;
  24. typedef void (*I2C_FUNC)(uint32_t u32Status);
  25. static volatile I2C_FUNC s_I2C0HandlerFn = NULL;
  26. /*---------------------------------------------------------------------------------------------------------*/
  27. /*  I2C0 IRQ Handler        */
  28. /*---------------------------------------------------------------------------------------------------------*/
  29. void I2C0_IRQHandler(void)
  30. {
  31.     uint32_t u32Status;
  32.     u32Status = I2C_GET_STATUS(I2C0);
  33.     if(I2C_GET_TIMEOUT_FLAG(I2C0))
  34.     {
  35.         /* Clear I2C0 Timeout Flag */
  36.         I2C_ClearTimeoutFlag(I2C0);
  37.     }
  38.     else
  39.     {
  40.         if(s_I2C0HandlerFn != NULL)
  41.             s_I2C0HandlerFn(u32Status);
  42.     }
  43. }
  44. /*---------------------------------------------------------------------------------------------------------*/
  45. /*  I2C Rx Callback Function        */
  46. /*---------------------------------------------------------------------------------------------------------*/
  47. void I2C_MasterRx(uint32_t u32Status)
  48. {
  49.     if(u32Status == 0x08)                       /* START has been transmitted and prepare SLA+W */
  50.     {
  51.         I2C_SET_DATA(I2C0, (g_u8DeviceAddr << 1));    /* Write SLA+W to Register I2CDAT */
  52.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  53.     }
  54.     else if(u32Status == 0x18)                  /* SLA+W has been transmitted and ACK has been received */
  55.     {
  56.         I2C_SET_DATA(I2C0, g_au8TxData[g_u8DataLen++]);
  57.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  58.     }
  59.     else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NACK has been received */
  60.     {
  61.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_STO_SI);
  62.     }
  63.     else if(u32Status == 0x28)                  /* DATA has been transmitted and ACK has been received */
  64.     {
  65.         if(g_u8DataLen != 2)
  66.         {
  67.             I2C_SET_DATA(I2C0, g_au8TxData[g_u8DataLen++]);
  68.             I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  69.         }
  70.         else
  71.         {
  72.             I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_SI);
  73.         }
  74.     }
  75.     else if(u32Status == 0x10)                  /* Repeat START has been transmitted and prepare SLA+R */
  76.     {
  77.         I2C_SET_DATA(I2C0, ((g_u8DeviceAddr << 1) | 0x01));   /* Write SLA+R to Register I2CDAT */
  78.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  79.     }
  80.     else if(u32Status == 0x40)                  /* SLA+R has been transmitted and ACK has been received */
  81.     {
  82.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  83.     }
  84.     else if(u32Status == 0x58)                  /* DATA has been received and NACK has been returned */
  85.     {
  86.         g_u8RxData = (unsigned char) I2C_GET_DATA(I2C0);
  87.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STO_SI);
  88.         g_u8EndFlag = 1;
  89.     }
  90.     else
  91.     {
  92.         /* TO DO */
  93.         printf("Status 0x%x is NOT processed\n", u32Status);
  94.     }
  95. }
  96. /*---------------------------------------------------------------------------------------------------------*/
  97. /*  I2C Tx Callback Function        */
  98. /*---------------------------------------------------------------------------------------------------------*/
  99. void I2C_MasterTx(uint32_t u32Status)
  100. {
  101.     if(u32Status == 0x08)                       /* START has been transmitted */
  102.     {
  103.         I2C_SET_DATA(I2C0, g_u8DeviceAddr << 1);    /* Write SLA+W to Register I2CDAT */
  104.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  105.     }
  106.     else if(u32Status == 0x18)                  /* SLA+W has been transmitted and ACK has been received */
  107.     {
  108.         I2C_SET_DATA(I2C0, g_au8TxData[g_u8DataLen++]);
  109.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  110.     }
  111.     else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NACK has been received */
  112.     {
  113.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_STO_SI);
  114.     }
  115.     else if(u32Status == 0x28)                  /* DATA has been transmitted and ACK has been received */
  116.     {
  117.         if(g_u8DataLen != 3)
  118.         {
  119.             I2C_SET_DATA(I2C0, g_au8TxData[g_u8DataLen++]);
  120.             I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
  121.         }
  122.         else
  123.         {
  124.             I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STO_SI);
  125.             g_u8EndFlag = 1;
  126.         }
  127.     }
  128.     else
  129.     {
  130.         /* TO DO */
  131.         printf("Status 0x%x is NOT processed\n", u32Status);
  132.     }
  133. }
  134. void SYS_Init(void)
  135. {
  136.     /*---------------------------------------------------------------------------------------------------------*/
  137.     /* Init System Clock        */
  138.     /*---------------------------------------------------------------------------------------------------------*/
  139.     /* Enable Internal RC 22.1184MHz clock */
  140.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  141.     /* Waiting for Internal RC clock ready */
  142.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  143.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  144.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  145.     /* Enable external XTAL 12MHz clock */
  146.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  147.     /* Waiting for external XTAL clock ready */
  148.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  149.     /* Set core clock as PLL_CLOCK from PLL */
  150.     CLK_SetCoreClock(PLL_CLOCK);
  151.     /* Enable UART & I2C0 module clock */
  152.     CLK_EnableModuleClock(UART0_MODULE);
  153.     CLK_EnableModuleClock(I2C0_MODULE);
  154.     /* Select UART module clock source */
  155.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  156.     /*---------------------------------------------------------------------------------------------------------*/
  157.     /* Init I/O Multi-function        */
  158.     /*---------------------------------------------------------------------------------------------------------*/
  159.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  160.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  161.     SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
  162.     /* Configure the SDA0 & SCL0 of I2C0 pins */
  163.     SYS->P3_MFP &= ~(SYS_MFP_P34_Msk | SYS_MFP_P35_Msk);
  164.     SYS->P3_MFP |= SYS_MFP_P34_SDA0 | SYS_MFP_P35_SCL0;
  165. }
  166. void UART0_Init()
  167. {
  168.     /*---------------------------------------------------------------------------------------------------------*/
  169.     /* Init UART        */
  170.     /*---------------------------------------------------------------------------------------------------------*/
  171.     /* Reset IP */
  172.     SYS_ResetModule(UART0_RST);
  173.     /* Configure UART0 and set UART0 Baudrate */
  174.     UART_Open(UART0, 115200);
  175. }
  176. void I2C0_Init(void)
  177. {
  178.     /* Open I2C module and set bus clock */
  179.     I2C_Open(I2C0, 100000);
  180.     /* Get I2C0 Bus Clock */
  181.     printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
  182.     /* Set I2C 4 Slave Addresses */
  183.     I2C_SetSlaveAddr(I2C0, 0, 0x15, 0);   /* Slave Address : 0x15 */
  184.     I2C_SetSlaveAddr(I2C0, 1, 0x35, 0);   /* Slave Address : 0x35 */
  185.     I2C_SetSlaveAddr(I2C0, 2, 0x55, 0);   /* Slave Address : 0x55 */
  186.     I2C_SetSlaveAddr(I2C0, 3, 0x75, 0);   /* Slave Address : 0x75 */
  187.     /* Enable I2C interrupt */
  188.     I2C_EnableInt(I2C0);
  189.     NVIC_EnableIRQ(I2C0_IRQn);
  190. }
  191. void I2C0_Close(void)
  192. {
  193.     /* Disable I2C0 interrupt and clear corresponding NVIC bit */
  194.     I2C_DisableInt(I2C0);
  195.     NVIC_DisableIRQ(I2C0_IRQn);
  196.     /* Disable I2C0 and close I2C0 clock */
  197.     I2C_Close(I2C0);
  198.     CLK_DisableModuleClock(I2C0_MODULE);
  199. }
  200. int32_t I2C0_Read_Write_SLAVE(uint8_t slvaddr)
  201. {
  202.     uint32_t i;
  203.     g_u8DeviceAddr = slvaddr;
  204.     for(i = 0; i < 0x100; i++)
  205.     {
  206.         g_au8TxData[0] = (uint8_t)((i & 0xFF00) >> 8);
  207.         g_au8TxData[1] = (uint8_t)(i & 0x00FF);
  208.         g_au8TxData[2] = (uint8_t)(g_au8TxData[1] + 3);
  209.         g_u8DataLen = 0;
  210.         g_u8EndFlag = 0;
  211.         /* I2C function to write data to slave */
  212.         s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTx;
  213.         /* I2C as master sends START signal */
  214.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA);
  215.         /* Wait I2C Tx Finish */
  216.         while(g_u8EndFlag == 0);
  217.         g_u8EndFlag = 0;
  218.         /* I2C function to read data from slave */
  219.         s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterRx;
  220.         g_u8DataLen = 0;
  221.         g_u8DeviceAddr = slvaddr;
  222.         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA);
  223.         /* Wait I2C Rx Finish */
  224.         while(g_u8EndFlag == 0);
  225.         /* Compare data */
  226.         if(g_u8RxData != g_au8TxData[2])
  227.         {
  228.             printf("I2C Byte Write/Read Failed, Data 0x%x\n", g_u8RxData);
  229.             return -1;
  230.         }
  231.     }
  232.     printf("Master Access Slave (0x%X) Test OK\n", slvaddr);
  233.     return 0;
  234. }
  235. /*---------------------------------------------------------------------------------------------------------*/
  236. /*  Main Function        */
  237. /*---------------------------------------------------------------------------------------------------------*/
  238. int32_t main(void)
  239. {
  240.     /* Unlock protected registers */
  241.     SYS_UnlockReg();
  242.     /* Init System, IP clock and multi-function I/O */
  243.     SYS_Init();
  244.     /* Init UART0 for printf */
  245.     UART0_Init();
  246.     /* Lock protected registers */
  247.     SYS_LockReg();
  248.     /*
  249.         This sample code sets I2C bus clock to 100kHz. Then, Master accesses Slave with Byte Write
  250.         and Byte Read operations, and check if the read data is equal to the programmed data.
  251.     */
  252.     printf("\n");
  253.     printf("+-------------------------------------------------------+\n");
  254.     printf("| M05xx I2C Driver Sample Code(Master) for access Slave |\n");
  255.     printf("|                                                       |\n");
  256.     printf("| I2C Master (I2C0) <---> I2C Slave(I2C0)               |\n");
  257.     printf("+-------------------------------------------------------+\n");
  258.     printf("Configure I2C0 as a master.\n");
  259.     printf("The I/O connection for I2C0:\n");
  260.     printf("I2C0_SDA(P3.4), I2C0_SCL(P3.5)\n");
  261.     /* Init I2C0 */
  262.     I2C0_Init();
  263.     printf("\n");
  264.     printf("Check I2C Slave(I2C0) is running first!\n");
  265.     printf("Press any key to continue.\n");
  266.     getchar();
  267.     /* Access Slave with no address */
  268.     printf("\n");
  269.     printf(" == No Mask Address ==\n");
  270.     I2C0_Read_Write_SLAVE(0x15);
  271.     I2C0_Read_Write_SLAVE(0x35);
  272.     I2C0_Read_Write_SLAVE(0x55);
  273.     I2C0_Read_Write_SLAVE(0x75);
  274.     printf("SLAVE Address test OK.\n");
  275.     /* Access Slave with address mask */
  276.     printf("\n");
  277.     printf(" == Mask Address ==\n");
  278.     I2C0_Read_Write_SLAVE(0x15 & ~0x01);
  279.     I2C0_Read_Write_SLAVE(0x35 & ~0x04);
  280.     I2C0_Read_Write_SLAVE(0x55 & ~0x01);
  281.     I2C0_Read_Write_SLAVE(0x75 & ~0x04);
  282.     printf("SLAVE Address Mask test OK.\n");
  283.     s_I2C0HandlerFn = NULL;
  284.     /* Close I2C0 */
  285.     I2C0_Close();
  286.     return 0;
  287. }
 楼主| yiy 发表于 2019-4-14 23:21 | 显示全部楼层
这个用到了指针,非常有趣
734774645 发表于 2019-4-15 09:19 | 显示全部楼层
这种始终不会
huangcunxiake 发表于 2019-4-15 20:30 | 显示全部楼层
比ST的这个接口好用
幸福小强 发表于 2019-4-15 23:15 | 显示全部楼层
上面函数指针的用法很奇特,学到了。
643757107 发表于 2019-4-15 23:31 | 显示全部楼层
修改指针地址实现同一个中断执行不同的内容。
643757107 发表于 2019-4-15 23:32 | 显示全部楼层
那个方法比STM32 回调还好用
玛尼玛尼哄 发表于 2019-4-16 00:31 | 显示全部楼层
看备注,这是回调的一种实现方式。
mintspring 发表于 2019-4-16 00:38 | 显示全部楼层
volatile 是关键,必须定义对。
21mengnan 发表于 2019-4-16 13:19 | 显示全部楼层
这个学到不少技术。
condition 发表于 2019-4-16 16:07 | 显示全部楼层
学习一下!I2C一直用的模拟
jiekou001 发表于 2019-4-16 17:10 | 显示全部楼层
可以用IIC的存储芯片做学习用。
深圳陈奕迅 发表于 2019-4-17 13:05 来自手机 | 显示全部楼层
如果要连续读两个字节呢
643757107 发表于 2019-4-18 00:30 | 显示全部楼层
要学会这种高级用法。
天灵灵地灵灵 发表于 2019-4-19 00:02 | 显示全部楼层
外设的使用都是一样的,搞懂一个,其他的库函数方法就搞定了
734774645 发表于 2019-4-20 08:12 | 显示全部楼层
是怎么知道I2C的地址的?
yiy
114
