[项目外包]
超高压陶瓷电容器
822|0
hanxing002|  楼主 | 2019-4-18 10:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
价格:¥3000000 元
发布时间:2019-04-18 09:58:29
截止时间:2019-05-18 09:58:29
项目周期:30天以上
现居地址:广东省东莞市东莞市
项目描述:
        Specification of High Voltage Ceramic Disc Capacitor
                                        Model
                                        型号
                                        CT82-6KV-D12-F9.5-102K
                                        Color
                                        颜色
                                        Dark Blue
                                        深蓝
                                        Condition of Testing
                                        试验条件
                                        Frequency
                                        频率
                                        Temperature
                                        温度
                                        Humidity
                                        湿度
                                        1KHZ
                                        22℃
                                        70%
        Static Capacitance
        容量
                                        1000PF
                                        Outline Size
                                        https://bbs.21ic.com/api/file://C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml1552/wps2.png
        Withstand Voltage
        耐压
                                        ≥9KV
        Capacitance Range
        容量范围
                                        ±10%
        Dissipation
        损耗角
                                        ≤1%
        Insulation Resistance
        绝缘电阻
        ≥100000MΩ
        Temperature
        Characteristics
        温度特性
                                        Y5T
        Operating Temperature
        工作温度
                                        -25℃~+85℃
                                        Pitch (F)
                                        脚距
                                        9.5±0.3mm
                                        Diameter× Thickness
        (MAX)直径厚度
                                        12×6mm
                                        Diameter of Lead Wire
        引出线直径
                                        0.6±0.02mm
                                        Length of Encapsulated Lead Wire (MAX)
                                        包封脚长
                                        3 mm
                                        Length of Lead Wire
        引线长度
                                        25+/- 2 mm
                                        Application
                                        应用
        Indispensable components for high voltage or the UHF instruments, machinery, X-ray machine, precision type instrument, medical equipment, aerospace, high voltage generator, anion generator, voltage regulator, electric power equipment, meters, home appliances, electrostatic paint spray equipment, military equipment, detector equipment, many other products and industrial applications.
去竞标
