AVR 片内EEPROM问题
1014|0
pkat|  楼主 | 2011-10-24 17:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<iom16v.h>
#include<macros.h>
#define uchar unsigned char
#define uint unsigned int
uchar unm[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar unm1[]={0x01,0x02,0x04,0x08};
uchar wei[]={0,0,0,0};
void init(void)
  DDRB=0XFF;
  DDRC=0X0F;
void xianshi(uchar a)
  uchar i;
  wei[3]=a/1000;
  wei[2]=a%1000/100;
  wei[1]=a%100/10;
  wei[0]=a%10;
  for(i=0;i<4;i++)
    PORTB=unm[wei];
PORTC=unm1;
void EEPROM_write(uint a,uint b)
  SREG&=~BIT(7);
  while(EECR&BIT(EEWE));
  EEAR=a;
  EEDR=b;
  EECR|BIT(EEMWE);
  EECR|=BIT(EEWE);
  SREG|=BIT(7);
uchar EEPROM_read(uint c)
  uchar s;
  SREG&=~BIT(7);
  EEAR=c;
  EECR|=BIT(EERE);
  s=EEDR;
  return s;
void main(void)
  uchar e;
  init();
  e=EEPROM_read(2);
  e++;
  EEPROM_write(2,e);
  while(1)
    xianshi(e);
  为什么无反应?
