欧比特 第一款跑Linux的 STM32核心板
1748|2
wenming|  楼主 | 2019-7-17 08:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The SOM1570, combines the  STM32MP157 multi-core application processor with up to 1GB DDR3L, up to 32MB QSPI flash, up to 64GB eMMC and a 1Gb Ethernet PHY module on a SOM(system on module).
Intefaces:
  • 10/100/1000M Ethernet with on board Ethernet PHY AR8033
  • 4 × UART + 4 × USART (12.5 Mbit/s, ISO7816 interface, LIN, IrDA, SPI slave)
  • 6 × SPI (50 Mbit/s, including 3 with full duplex I2S audio class accuracy via internal audio PLL or external clock)
  • 4 × SAI (stereo audio: I2S, PDM, SPDIF Tx)
  • 2 × SDMMC up to 8-bit (SD / e•MMC™ / SDIO)
  • 2 × CAN controllers supporting CAN FD protocol, out of which one supports time-triggered CAN (TTCAN)
  • 1 × USB 2.0 high-speed Host+ 1 × USB 2.0 high-speed OTG simultaneously
  • LCD-TFT controller, up to 24-bit , WXGA (1366 × 768) @60 fps
  • MIPI® DSI 2 data lanes up to 1 GHz each
Features:
  • 32-bit dual-core Arm® Cortex®-A7
  • 32-bit Arm® Cortex®-M4 with FPU/MPU
  • 3D GPU: Vivante® - OpenGL® ES 2.0,Up to 26 Mtriangle/s, 133 Mpixel/s
  • Security chip ATECC608A
  • Hardware Watchdog
  • On board Qspi flash
  • On board eMMC
  • Sodimm linke  form fact 68*38 mm
wenming|  楼主 | 2019-9-8 13:26 | 只看该作者
可以出货了
123654789| | 2020-3-13 12:16 | 只看该作者
个人签名:嵌入式Linux工业控制板,提供ODM与OEM,只做批量,不卖开发板! 欧比特测控   www.OpenEmbed.com
108
