[DemoCode下载] ML51基于寄存器的ADC多通道配置
838|2
 楼主| 捉虫天师 发表于 2019-11-29 21:28 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Website: http://www.nuvoton.com
  8. //  E-Mail : MicroC-8bit@nuvoton.com
  9. //  Date   : Jan/21/2019
  10. //***********************************************************************************************************
  11. //***********************************************************************************************************
  12. //  File Function: ML51 ADC multi channel input demo code
  13. //***********************************************************************************************************
  14. #include "ML51.H"
  15. unsigned char xdata ADCdataAIN5H, ADCdataAIN5L;
  16. unsigned char xdata ADCdataVBGH, ADCdataVBGL;
  17. /******************************************************************************
  18. The main C function.  Program execution starts
  19. here after stack initialization.
  20. ******************************************************************************/
  21. void main (void)
  22. {
  23.   /* UART0 settting for printf function */
  24.     MFP_P31_UART0_TXD;
  25.     P31_PUSHPULL_MODE;
  26.     UART_Open(24000000,UART0_Timer3,115200);
  27.     ENABLE_UART0_PRINTF;
  28.
  29. /*Enable channel 5 */
  30.       ENABLE_ADC_AIN5;
  31.       ADCCON1|=0X30;            /* clock divider */
  32.       ADCCON2|=0X0E;            /* AQT time */
  33.       AUXR1|=SET_BIT4;          /* ADC clock low speed */
  34.       clr_ADCCON0_ADCF;
  35.       set_ADCCON0_ADCS;
  36.       while(ADCCON0&0x10 == 0);
  37.       ADCdataAIN5H = ADCRH;
  38.       ADCdataAIN5L = ADCRL;
  39.       DISABLE_ADC;
  40. //      printf("\n ADC channel 5 =0x%bx", ADCdataAIN5H);
  41. /*Enable Bandgap */
  42.       ENABLE_ADC_BANDGAP;
  43.       ADCCON1|=0X30;            /* clock divider */
  44.       ADCCON2|=0X0E;            /* AQT time */
  45.       AUXR1|=SET_BIT4;          /* ADC clock low speed */
  46.       clr_ADCCON0_ADCF;
  47.       set_ADCCON0_ADCS;
  48.       while(ADCCON0&0x10 == 0);
  49.       ADCdataVBGH = ADCRH;
  50.       ADCdataVBGL = ADCRL;
  51.       DISABLE_ADC;
  52. //      printf("\n ADC channel bandgap =0x%bx", ADCdataVBGH);
  53.
  54.     while(1);
  55. }
jiekou001 发表于 2019-11-29 21:41 | 显示全部楼层
看起来代码挺亲切的,51代码还是不错的。
小明的同学 发表于 2019-12-1 19:16 | 显示全部楼层
这种宏定义很容易理解啥意思,根本用不到备注了。
