[MSP430]
用G2553的三线SPI通信,没有有门控信号EN???
604|6
niubohuaii|  楼主 | 2019-12-12 20:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
dirtwillfly| | 2019-12-12 21:56 | 只看该作者
msp430g系列上叫UCxSTE,记得P1.5和P1.4分别是UCA0和UCB0做spi功能时的从设备使能
niubohuaii|  楼主 | 2019-12-13 09:40 | 只看该作者
If data is written into UCxTXBUF while the master is held inactive by UCxSTE, it will be transmitted as
soon as UCxSTE transitions to the master-active state. If an active transfer is aborted by UCxSTE
transitioning to the master-inactive state, the data must be re-written into UCxTXBUF to be transferred
when UCxSTE transitions back to the master-active state. The UCxSTE input signal is not used in 3-pin master mode.
这是手册上的原话,最后一句说3线不用UCxCTE,难道我理解的不对吗·····
一路向北lm| | 2019-12-13 09:52 | 只看该作者
没有 EN 就是直接使能了啊
dirtwillfly| | 2019-12-13 13:01 | 只看该作者
niubohuaii 发表于 2019-12-13 09:40
If data is written into UCxTXBUF while the master is held inactive by UCxSTE, it will be transmitt ...
你的理解没错。msp430的三线制不使用UCxCTE,从设备的使能引脚直接接到相应的电平就可以了。
niubohuaii 2019-12-13 15:36 回复TA
好的,谢谢
niubohuaii|  楼主 | 2019-12-13 15:36 | 只看该作者
一路向北lm 发表于 2019-12-13 09:52
没有 EN 就是直接使能了啊
谢谢
