[资料分享]
具有电感式传感的低功耗水流测量参考设计 TIDA-01228
359|19
dirtwillfly|  楼主 | 2019-12-30 22:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
This reference design demonstrates a highly-integrated solution for this application using an inductive sensing technique enabled by the CC1350 SimpleLink™ Wireless MCU and FemtoFET™ MOSFET. This reference design also provides the platform for integration of wireless communications such as wireless M-Bus, Sigfox™, or a proprietary protocol. Water utility providers who wish to add Automatic Meter Reading (AMR) capability face the choice of replacing all of their existing meters or installing a simple electronic add-on module, which will accurately measure the water flow rate and wirelessly transmit the results. Such add-on modules can provide the least expensive solution to provide AMR features to consumers.
特性
  • Meets measurement accuracy requirements of ISO4064-1:2014-11 (Class 1)
  • Accurate measurement at a distance of 4.2 mm to a wheel (11mm diameter)
  • Accurate flow measurement as low as 11.25 liters per hour
  • Consumes only 4µA with 12Hz sampling rate
  • Support ISM bands in 431 to 527MHz and 861 to 1054MHz range plus Bluetooth® Low Energy at 2.4GHz
dirtwillfly|  楼主 | 2019-12-30 22:21 | 只看该作者
具有电感式传感功能的低功耗水流测量参考设计 (Rev. A).pdf (2.36 MB)
dirtwillfly|  楼主 | 2019-12-30 22:22 | 只看该作者
Modernizing the grid to make it more resilient and reliable through technology.pdf (1.1 MB)
dirtwillfly|  楼主 | 2019-12-30 22:23 | 只看该作者
TIDA-01228 Gerber.zip (486.54 KB)
TIDA-01228 CAD Files.zip (327.11 KB)
dirtwillfly|  楼主 | 2019-12-30 22:24 | 只看该作者
TIDA-01228 PCB.pdf (471.77 KB)
dirtwillfly|  楼主 | 2019-12-30 22:25 | 只看该作者
TIDA-01228 Assembly Drawing.pdf (117.15 KB)
dirtwillfly|  楼主 | 2019-12-30 22:26 | 只看该作者
TIDA-01228 BOM.pdf (64.78 KB)
dirtwillfly|  楼主 | 2019-12-30 22:27 | 只看该作者
TIDA-01228 Schematic.pdf (145.82 KB)
dirtwillfly|  楼主 | 2019-12-30 22:46 | 只看该作者
TIDA-01228.zip (7.47 MB)
gwsan| | 2020-1-6 10:24 | 只看该作者
非常感谢楼主分享
kxsi| | 2020-1-6 10:30 | 只看该作者
非常感谢楼主分享
nawu| | 2020-1-6 10:34 | 只看该作者
非常感谢楼主分享
qcliu| | 2020-1-6 10:38 | 只看该作者
非常感谢楼主分享
tfqi| | 2020-1-6 10:41 | 只看该作者
非常感谢楼主分享
wiba| | 2020-1-6 10:44 | 只看该作者
非常感谢楼主分享
zljiu| | 2020-1-6 10:49 | 只看该作者
非常感谢楼主分享
coshi| | 2020-1-6 10:52 | 只看该作者
非常感谢楼主分享
aoyi| | 2020-1-6 10:59 | 只看该作者
非常感谢楼主分享
drer| | 2020-1-6 11:11 | 只看该作者
非常感谢楼主分享
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
