[资料分享]
支持 M-Bus 和 RS-485 协议转换的数据收集器参考设计 TIDM-1005
967|35
dirtwillfly|  楼主 | 2020-3-31 21:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
This reference design implements a smart meter data collector with protocol conversion between Meter Bus (M-Bus) and RS-485 networks. M-BUS and RS-485 networks can be mixed together in some network domains, requiring bridging capability to fully integrate the system. This design becomes an intermediate node that collects M-BUS data packets from individual flow meters and formats them for transmission across a larger RS-485 network to the primary data concentrator.
特性
  • Simple data collector with protocol conversion between M-Bus and RS-485 transceiver for cost-constrained applications
  • Isolated power supply output 24V to provide sufficient power for M-Bus master module to support more than 100 M-Bus slaves, 3.3V to power MSP432, and 5V to power RS-485 signal chain
  • Tested +/-2KV IEC61000-4-4 EFT, +/-8KV IEC61000-4-2 ESD, and CISPR22 Class-B conducted emission
  • The reference design EVM with extra pinouts (for SPI, UART, and GPIO) and the software examples allow ease of evaluation to support other wireless and wired communication protocols
dirtwillfly|  楼主 | 2020-3-31 21:25 | 只看该作者
支持M-Bus 和RS-485 协议转换的数据收集器参考设计 (Rev. A).pdf (6.97 MB)
tfqi| | 2020-4-2 13:22 | 只看该作者
非常感谢楼主分享
wiba| | 2020-4-2 13:22 | 只看该作者
非常感谢楼主分享
zljiu| | 2020-4-2 13:23 | 只看该作者
非常感谢楼主分享
coshi| | 2020-4-2 13:23 | 只看该作者
非常感谢楼主分享
aoyi| | 2020-4-2 13:23 | 只看该作者
非常感谢楼主分享
dirtwillfly|  楼主 | 2020-6-22 16:49 | 只看该作者
Data Collector With M-Bus And RS-485 Protocol Conversion Gerber.zip (362.72 KB)
Data Collector With M-Bus And RS-485 Protocol Conversion CAD Files.zip (2.11 MB)
dirtwillfly|  楼主 | 2020-6-22 16:51 | 只看该作者
Data Collector With M-Bus And RS-485 Protocol Conversion PCB.pdf (1.05 MB)
Data Collector With M-Bus And RS-485 Protocol Conversion Assembly Drawing.pdf (257.55 KB)
dirtwillfly|  楼主 | 2020-6-22 16:53 | 只看该作者
Data Collector With M-Bus And RS-485 Protocol Conversion BOM.pdf (107.01 KB)
dirtwillfly|  楼主 | 2020-6-22 17:22 | 只看该作者
Data Collector With M-Bus And RS-485 Protocol Conversion Schematic.pdf (424.97 KB)
dirtwillfly|  楼主 | 2020-6-22 17:23 | 只看该作者
usysm| | 2020-7-8 20:35 | 只看该作者
modbus协议与RS485是同一种么
typeof| | 2020-7-8 20:35 | 只看该作者
rs-485和cmbus都是四线制?
yujielun| | 2020-7-8 20:35 | 只看该作者
htmlme| | 2020-7-8 20:36 | 只看该作者
M-Bus和C-MBus,这两个协议有什么区别?
pklong| | 2020-7-8 20:36 | 只看该作者
典型的串行通讯标准是RS232和RS485
touser| | 2020-7-8 20:37 | 只看该作者
RS422/485最大通讯距离是1200米
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
