keil5如何生成bin文件
220|0
求关注啊|  楼主 | 2019-11-20 12:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
After Build - User command #1: "E:\MDK Keil\eiKMdAr514\Keil MDK-ARM 5.14\ARM\ARMCC\bin\fromelf.exe --bin -o ..\..\Output\Template.bin "
*** Error: CreateProcess failed, Command: '"E:\MDK Keil\eiKMdAr514\Keil MDK-ARM 5.14\ARM\ARMCC\bin\fromelf.exe --bin -o ..\..\Output\Template.bin "'
"..\..\Output\Template.axf" - 1 Error(s), 0 Warning(s).
