gcc可以通过 cl无法通过 什么问题
338|0
limee|  楼主 | 2020-6-16 15:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#ifdef __ICL
#define DECLARE_ALIGNED( var, n ) __declspec(align(n)) var
#else
#define DECLARE_ALIGNED( var, n ) var __attribute__((aligned(n)))
#endif
#define ALIGNED_16( var ) DECLARE_ALIGNED( var, 16 )
#define ALIGNED_8( var )  DECLARE_ALIGNED( var, 8 )
#define ALIGNED_4( var )  DECLARE_ALIGNED( var, 4 )
#include <stdint.h>
typedef uint16_t pixel;
struct x264_weight_t;
typedef struct x264_weight_t
    /* aligning the first member is a gcc hack to force the struct to be
     * 16 byte aligned, as well as force sizeof(struct) to be a multiple of 16
    ALIGNED_16(int16_t cachea[8]);
    int16_t cacheb[8];
    int32_t i_denom;
    int32_t i_scale;
    int32_t i_offset;
}x264_weight;
只要把宏ALIGNED_16注释掉,cl也是可以通过的。
什么问题啊?
