MPU6050自检程序
648|0
 楼主| 香菇选手 发表于 2018-7-26 19:04 | 显示全部楼层 |阅读模式
近来使用了MPU6050芯片,芯片本身带有自检功能,网上搜了一下发现并没有现成的程序,便自己写了一个,分享给大家!请看源代码:
[mw_shl_code=c,true]u8 MPU_SelfTest(void)
        s16 ax,ay,az,gx,gy,gz,str_ax,str_ay,str_az,str_gx,str_gy,str_gz,t;
        u8 buff[4]={0},test_ax,test_ay,test_az,test_gx,test_gy,test_gz;
        float a;
        MPU_WriteData(MPU_GYRO_CFG_REG,0xe0);          //设置陀螺仪三轴自检,并设置满了量程范围为±250dps
        MPU_WriteData(MPU_ACCEL_CFG_REG,0xf0);         //设置加速度计三轴自检,并设置满了量程范围为±8g
        MPU_GetOrigData(&str_ax,&str_ay,&str_az,&str_gx,&str_gy,&str_gz,&t); //读取数据
        MPU_WriteData(MPU_GYRO_CFG_REG,0x00);          //设置陀螺仪三轴不自检,并设置满了量程范围为±250dps
        MPU_WriteData(MPU_ACCEL_CFG_REG,0x10);         //设置加速度计三轴不自检,并设置满了量程范围为±8g
        MPU_GetOrigData(&ax,&ay,&az,&gx,&gy,&gz,&t);   //读取数据
        //计算STR
        str_ax -= ax;
        str_ay -= ay;
        str_az -= az;
        str_gx -= gx;
        str_gy -= gy;
        str_gz -= gz;
        //读取自检寄存器
        IIC_ReadData(buff,4,MPU6050_ADDR,MPU_SELF_TESTX_REG);
        test_gx = buff[0] & 0x1f;
        test_gy = buff[1] & 0x1f;
        test_gz = buff[2] & 0x1f;
        test_ax = ((buff[0] & 0xe0)>>3)+((buff[3]&0x30)>>4);
        test_ay = ((buff[1] & 0xe0)>>3)+((buff[3]&0x0c)>>2);
        test_az = ((buff[2] & 0xe0)>>3)+(buff[3]&0x03);
        //计算FT
        gx = test_gx==0 ? 0:25*131*pow(1.046,test_gx-1);
        gy = test_gy==0 ? 0:-25*131*pow(1.046,test_gy-1);
        gz = test_gz==0 ? 0:25*131*pow(1.046,test_gz-1);
        ax = test_ax==0 ? 0:4096*0.34*pow(0.92/0.34,(test_ax-1)/30.0);
        ay = test_ay==0 ? 0:4096*0.34*pow(0.92/0.34,(test_ay-1)/30.0);
        az = test_az==0 ? 0:4096*0.34*pow(0.92/0.34,(test_az-1)/30.0);
        //计算自检响应
        mpu6050.Acc_selftest.x = ((float)(str_ax-ax)/ax);
        mpu6050.Acc_selftest.y = ((float)(str_ay-ay)/ay);
        mpu6050.Acc_selftest.z = ((float)(str_az-az)/az);
        mpu6050.Gyro_selftest.x = ((float)(str_gx-gx)/gx);
        mpu6050.Gyro_selftest.y = ((float)(str_gy-gy)/gy);
        mpu6050.Gyro_selftest.z = ((float)(str_gz-gz)/gz);
        MPU_WriteData(MPU_GYRO_CFG_REG,3<<3);          //恢复初始设置
        MPU_WriteData(MPU_ACCEL_CFG_REG,0<<3);
        if(fabs(mpu6050.Acc_selftest.x)<14 && fabs(mpu6050.Acc_selftest.y)<14 && fabs(mpu6050.Acc_selftest.z)<14 && fabs(mpu6050.Gyro_selftest.x)<14 && fabs(mpu6050.Gyro_selftest.y)<14 && fabs(mpu6050.Gyro_selftest.z)<14)
                return 0;
        else
          return 1;
}[/mw_shl_code]
MPU6050数据手册和寄存器手册上也说的非常明白了,值得注意的是:自检时陀螺仪量程必须是±250dps,加速度计量程必须是±8g,mpu6050.Acc_selftest.x、y、z,mpu6050.Gyro_selftest.x、y、z的绝对值小于14则自检通过。
程序中有几个函数没有给出源代码,现解释如下(其实看名称就能理解):
MPU_WriteData:使用IIC写数据给MPU6050,第一个参数是寄存器地址,第二个参数是要写入的数据;
MPU_GetOrigData:获取MPU6050三轴加速度和角速度值
IIC_ReadData:连续读取数据,第一个参数是读入的内存地址,第二个参数是读取的个数,第三个参数是MPU6050器件地址,第四个参数是寄存器地址。
自身水平有限,如有错误,请多多指教。
