用STM32F407 移植的SD卡初始化程序CMD55命令返回出错的问题求教高手
251|0
大碴子味|  楼主 | 2018-7-26 19:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用官方的407库文件移植SD卡驱动,我看了官方的流程,大致是 上电->CMD0 -> CMD8 ->CMD55 -> ACMD41    ....................
我在上电后,加了74个时钟脉冲,然后程序运行到CMD55命令式,不能返回SD_OK  而是返回的是:SD_ILLEGAL_CMD  官方的解释是:= (16), /*!< Command is not legal for the card state */
但是我换了好几张卡,都是这个样子的,请教高手,该如何解决
下面是源程序:
__IO SD_Error errorstatus = SD_OK;
  uint32_t response = 0, count = 0, validvoltage = 0;
  uint32_t SDType = SD_STD_CAPACITY;
/*?????????±?ò??72???±??*/
unsigned int TempCnt;
  /*!< Power ON Sequence -----------------------------------------------------*/
  /*!< Configure the SDIO peripheral */
  /*!< SDIO_CK = SDIOCLK / (SDIO_INIT_CLK_DIV + 2) */
  /*!< on STM32F4xx devices, SDIOCLK is fixed to 48MHz */
  /*!< SDIO_CK for initialization should not exceed 400 KHz */
  SDIO_InitStructure.SDIO_ClockDiv = SDIO_INIT_CLK_DIV;
  SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising;
  SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;
  SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;
  SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_1b;
  SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable;
  SDIO_Init(&SDIO_InitStructure);
  /*!< Set Power State to ON */
  SDIO_SetPowerState(SDIO_PowerState_ON);
// delay_ms(5000);   /*???±????SD?¨?????ê??*/
  /*!< Enable SDIO Clock */
  SDIO_ClockCmd(ENABLE);
delay_ms(1);
/********************************·???74???±??******************************/
SDIO_CmdInitStructure.SDIO_Argument = 0x0;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_GO_IDLE_STATE;
  SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_No;
  SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;
  SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;
for(TempCnt=0;TempCnt<74;TempCnt++)
   SDIO_SendCommand(&SDIO_CmdInitStructure);
   CmdError();
  /*!< CMD0: GO_IDLE_STATE ---------------------------------------------------*/
  /*!< No CMD response required */
  errorstatus = CmdError();
  if (errorstatus != SD_OK)
    /*!< CMD Response TimeOut (wait for CMDSENT flag) */
    return(errorstatus);
  /*!< CMD8: SEND_IF_COND ----------------------------------------------------*/
  /*!< Send CMD8 to verify SD card interface operating condition */
  /*!< Argument: - [31:12]: Reserved (shall be set to '0')
               - [11:8]: Supply Voltage (VHS) 0x1 (Range: 2.7-3.6 V)
               - [7:0]: Check Pattern (recommended 0xAA) */
  /*!< CMD Response: R7 */
  SDIO_CmdInitStructure.SDIO_Argument = SD_CHECK_PATTERN;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SEND_IF_COND;
  SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;
  errorstatus = CmdResp7Error();
  if (errorstatus == SD_OK)
    CardType = SDIO_STD_CAPACITY_SD_CARD_V2_0; /*!< SD Card 2.0 */
    SDType = SD_HIGH_CAPACITY;
&nbsprintfDebugCharParameter("SDCard V2.0: ",&errorstatus,1);
  else
    /*!< CMD55 */
    SDIO_CmdInitStructure.SDIO_Argument = 0x00;
    SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_APP_CMD;
    errorstatus = CmdResp1Error(SD_CMD_APP_CMD);
  /*!< CMD55 */
  /*!< If errorstatus is Command TimeOut, it is a MMC card */
  /*!< If errorstatus is SD_OK it is a SD card: SD card 2.0 (voltage range mismatch)
     or SD card 1.x */
    /*!< SD CARD */
    /*!< Send ACMD41 SD_APP_OP_COND with Argument 0x80100000 */
    while ((!validvoltage) && (count < SD_MAX_VOLT_TRIAL))
      /*!< SEND CMD55 APP_CMD with RCA as 0 */
   &nbsprintfDebugCharParameter("CMD55 Failed errorstatus: ",&errorstatus,1);
    continue ;
  &nbsprintfDebugCharParameter("CMD55 Successed! ",&errorstatus,1);
      SDIO_CmdInitStructure.SDIO_Argument = SD_VOLTAGE_WINDOW_SD | SDType;
      SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SD_APP_OP_COND;
      errorstatus = CmdResp3Error();
      response = SDIO_GetResponse(SDIO_RESP1);
      validvoltage = (((response >> 31) == 1) ? 1 : 0);
      count++;
    if (count >= SD_MAX_VOLT_TRIAL)
      errorstatus = SD_INVALID_VOLTRANGE;
    if (response &= SD_HIGH_CAPACITY)
      CardType = SDIO_HIGH_CAPACITY_SD_CARD;
  }/*!< else MMC Card */
