[资料干货]
华为海思芯片方案开发技术经验总结
1432|6
maximQ820270087|  楼主 | 2020-8-20 00:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
# 监控设备 Hi3516EV300 主流3M IP摄像机SoC
处理器主频:ARM Cortex-A7@ 900 MHz
视频编码性能:
Maximum resolution for H.264 /H.265 encoding: 2688 x 1520 or 2592 x 1944 (with the width up to 2688)
视频解码性能:无
视频分析能力:Integrated IVE,Various intelligent analysis applications
ISP : 3A
音频编解码能力:G.711, G.726, and ADPCM Audio 3A functions (AEC, ANR, and AGC)
视频输入接口:− 8-/10-/12-bit RGB Bayer DC timing video input. BT.1120 input is supported.− MIPI, LVDS/sub-LVDS, and HiSPi
视频输出接口:− 6-/8-/16-bit LCD output   - BT.656/BT.1120 output
音频接口:Integrated audio codec, I2S interface for connecting to external audio codec
外部功能接口:RTC,I2Cx3,SPIx2,GPIOs,UARTx3,PWMx4,LSADCx4,USB2.0,PHY,SDIOx2
价格特点:中偏低,$7左右
应用领域: 主流IPC行业,Baby Camera
## 监控设备 Hi3516EV200 主流全高清IP摄像机SoC
视频编码性能:Maximum resolution for H.264 /H.265 encoding: 2304 x
1296 (with the width up to 2304)
视频解码性能:无
ISP : 3A
视频输入接口:− 8-/10-/12-bit RGB Bayer DC timing VI − MIPI, LVDS/sub-LVDS, and HiSPi
视频输出接口:− 6-/8-bit LCD output
− BT.656/BT.1120 output
外部功能接口:RTC,I2Cx3,SPIx2,GPIOs,UARTx3,PWMx4,LSADCx2,USB2.0,PHY,SDIO,SD 2.0 card
价格特点:低 $5左右
应用领域: 主流IPC行业,Baby Camera,行车记录仪
## **监控设备 Hi3516EV100 主流全高清IP摄像机SoC**
处理器主频:ARM926@800 MHz
视频编码性能:Maximum resolution of 1536 x 1536 for H.264/H.265
视频解码性能:无
ISP : 3A
视频输入接口:8-/10-/12-/14-bit RGB Bayer DC timing VI
− BT.601, BT.656, and BT.1120 VI interfaces
视频输出接口:− One BT.656 VO interface
− 6-bit RGB565 serial LCD output
外部功能接口:RTC,I2Cx2,SSPx3,GPIOs,UARTx3,PWMx4,LSADCx3,USB2.0,SDIO2.0x2,PHY,IR
价格特点:中偏低
## 监控设备 Hi3516DV200 主流4M IP摄像机Soc
视频编码性能:Maximum resolution for H.264 /H.265 encoding: 3072 x 1728/2688 x 1944 (with the width up to 3072 and height up to 1944)
视频解码性能:无
ISP : 3A
外部功能接口:RTC,I2Cx3,SPIx2,GPIOs,UARTx3,PWMx4,LSADCx4,USB2.0,PHY,SDIO,SD 2.0 card
价格特点:中偏低 $10
## 监控设备 Hi3516AV300 专业5M智能IP摄像机Soc [AI 1T算力]
处理器主频:Dual-core ARM Cortex-A7@ 900 MHz
视频编码性能:Up to 3840-pixel wide and 3840 x 2160 resolution for
H.264/H.265 encoding and decoding.
视频解码性能:无
视频分析能力:Neural network acceleration engine with processing
performance up to 1.0 TOPS
ISP : 3A
视频输入接口:2-channel VI − 8-/10-/12-/14-bit RGB Bayer DC timing VI
视频输出接口:− One BT.656/BT.1120 VO interface
− 6-/8-bit RGB serial LCD VO and 16-/18-/24-bit RGB
外部功能接口:
价格特点:中偏低
应用领域: 智能视频分析IPC行业,图像识别
## 监控设备 Hi3559AV100 高端行业IP摄像机Soc [ AI 能力 ]
处理器主频:Dual-core ARM Cortex A73@1.8 GHz,Dual-core ARM Cortex A53@1.2 GHz,Single-core ARM Cortex A53@1 GHz,
视频编码性能:A maximum of 8192 x 8640 resolution for H.264
encoding  A maximum of 16384 x 8640 resolution for H.265
encoding
视频解码性能:无
视频分析能力:Quad-core DSP@700 MHz,Dual-core NNIE@840 MHz neural network acceleration
ISP : 3A
音频编解码能力:G.711, G.726, AAC, and other audio encoding formats  Audio 3A functions (AEC, ANR, and ALC)
视频输入接口:Eight sensor inputs  − 8-/10-/12-/14-bit RGB Bayer DC timing VI, up to 150
MHz clock frequency
视频输出接口:− HDMI 2.0, supporting maximum 4K@60 fps output
− 6-/8-/16-/24-bit RGB digital LCD output, supporting
maximum 1920 x 1080@60 fps output
外部功能接口:RTC,I2Cx4,SPPx4,GPIOs,UARTx5,PWMx8,LSADCx3,SDIO3.0x2,IR,PCIe2.0,USB3.0/USB2.0x2,GMACsx2
价格特点:高
应用领域:视觉分析,高端图像处理,行为识别,高端相机,8K相机
## 监控设备 Hi3518EV300 消费类摄像机Soc解决方案
处理器主频:ARM Cortex-A7@ 900 MHz,
视频解码性能:无
视频分析能力:Integrated IVE,Various intelligent analysis applications,
ISP : 3A
外部功能接口:RTC,I2Cx3,SPIx2,GPIOs,UARTx3,PWMx4,LSADCx2,USB2.0,SDIO2.0
价格特点:低
应用领域: 低端IPC行业,Baby Camera
## 监控设备 Hi3519AV100 先进的智能IP摄像机Soc
处理器主频:Dual-core ARM Cortex-A53@1.4 GHz,
视频编码性能:H.264,H.265,MJPEG/JPEG,4K x 2K (3840 x 2160)@60 fps or 1080p@240 fps
视频解码性能:H.264,H.265,MJPEG/JPEG
视频分析能力:Integrated Tensilica Vision P6 DSP@630 MHz  2.0 TOPS neural network computing performance
ISP : 3A
音频编解码能力:Audio encoding in formats such as G.711, G.726, and
AAC
视频输入接口:Up to 5-channel sensor serial inputs  MIPI, sub-
LVDS, HiSPi, and SLVS-EC interfaces
视频输出接口:HDMI 2.0, supporting up to 4K x 2K (4096 x 2160)@60
fps outputs
音频接口:Integrated audio codec, I2S interface,HDMI audio output
外部功能接口:RTC,I2C,SPI,GPIOs,UARTx9,PWMx8,LSADCx4,USB2.0/3.0,SDIO3.0x2,IR,GMAC
价格特点:中偏高,价格优于3559A
应用领域: 高端视频分析,多路拼接,AI视觉
## 监控设备 Hi3516CV500 主流2M智能IP摄像机SoCs
处理器主频:Dual-core ARM Cortex-A7@ 900 MHz,
视频编码性能:H.264,H.265,MJPEG/JPEG,Up to 2304-pixel wide and 2304 x 1296 resolution for
视频解码性能:无
performance up to 0.5 TOPS
ISP : 3A
视频输入接口:− 8-/10-/12-/14-bit RGB Bayer DC timing VI
parallel LCD VO
− 4-lane MIPI-DSI VO
外部功能接口:RTC,I2Cx7,SPIx3,GPIOs,UARTx4,PWMx3,LSADCx2,USB2.0/3.0,SDIO3.0x2,PHY
价格特点:$6.5-$8左右
## 监控设备 Hi3516DV300 专业4M智能IP摄像机SoC [中档1T算力,AI处理器]
视频解码性能:H.264,H.265,MJPEG/JPEG, Up to 2688-pixel wide and 2688 x 1944 resolution for
ISP : 3A
parallel LCD VO
外部功能接口:RTC,I2Cx8,SPIx3,GPIOs,UARTx5,PWMx3,LSADCx2,USB2.0/3.0,SDIO3.0x2,PHY,IR
价格特点:$12 左右
## 监控设备 Hi3519V101 先进的工业IP摄像机Soc
处理器主频:800 MHz A7 core,1.25G GHz A17 core,
视频编码性能:Maximum 16-megapixel (4608 x 3456) resolution for
视频解码性能:无
ISP : 3A
视频输入接口:Two sensor inputs.8-/10-/12-/14-bit RGB Bayer DC timing VI, at most
150 MHz clock frequency
视频输出接口:− − One PAL/NTSC output for automatic load detection
− One BT.1120/BT.656 VO interface for connecting to
an external HDMI or SDI, supporting at most
1080p@60 fps output
− LCD output
外部功能接口:RTC,I2Cx4,SSPx4,GPIOs,UARTx5,PWMx8,LSADCx3,USB2.0/3.0,SDIO3.0x2,PHY,IR,PCIe2.0
价格特点:价格偏高
应用领域: 主流IPC行业,Baby Camera,高端双目
## 监控设备 Hi3516AV200 主流行业IP摄像机Soc
视频编码性能:H.264,H.265,MJPEG/JPEG,Maximum 16-megapixel (4608 x 3456) resolution for
视频解码性能:无
ISP : 3A
视频输出接口:One PAL/NTSC output for automatic load detection
1080p@60 fps output
− LCD output
价格特点:中偏低
应用领域: 主流IPC行业,Baby Camera,双目相机
## 监控设备 Hi3516AV100 主流行业IP摄像机Soc
处理器主频:A7@600 MHz
视频编码性能:H.264,H.265,MJPEG/JPEG,A maximum of 5-megapixel resolution for H.264/H.265 encoding
视频解码性能:无
ISP : 3A
视频输入接口:8-/10-/12-/14-bit RGB Bayer DC timing VI, a
maximum of 150 MHz clock frequency
an external HDMI or SDI, up to
外部功能接口:RTC,I2Cx3,SSPx4,GPIOs,UARTx4,PWMx8,SAR-ADCx2,USB2.0,SDIO3.0x2,PHY,IR
价格特点:中
应用领域: 主流IPC行业,Baby Camera,编码器
## 监控设备 Hi3516DV100 先进的全高清IP摄像机Soc
处理器主频:A7@600 MHz,
encoding
视频解码性能:无
ISP : 3A
− BT.601, BT.656 or BT.1120 VI interface
− MIPI, LVDS/sub-LVDS, and HiSPI
an external HDMI or SDI, up to 1080p@60 fps output
价格特点:中偏低
## 监控设备 Hi3516CV300 主流全高清IP摄像机Soc
视频编码性能:H.264,H.265,MJPEG/JPEG,Maximum 2-megapixel resolution for H.264/H.265
encoding
视频解码性能:无
ISP : 3A
价格特点:中偏低
## **监控设备 Hi3518EV200/201 主流超高清IP相机SoC**
处理器主频:ARM926@540 MHz
视频编码性能:H.264 main/high profile L4.0 H.264 baseline encoding MJPEG/JPEG baseline encoding,A maximum of 2-megapixel resolution for H.264
encoding
视频解码性能:无
ISP : 3A
视频输入接口:− 8-, 10-, 12-, or 14-bit RGB Bayer/RGB-IR inputs,
maximum clock frequency of 100 MHz
− 4-Lane MIPI/HiSPI/LVDS VI interfaces
视频输出接口:− One BT.656 VO interface supporting 8-bit serial LCD
outputs
音频接口:Integrated audio codec, I2S input
外部功能接口:RTC,I2C/I2S,SSP,GPIOs,UARTx3,PWMx4,SAR-ADCx4,USB2.0,SDIOx2,PHY,IR
价格特点:偏低
应用领域: 主流低端H.264  IPC
Hi3516DV300硅天下.pdf (270.56 KB)
Hi3516AV100.pdf (233 KB)
Hi3516AV300.pdf (147.62 KB)
Hi3516CV300CN .pdf (339.54 KB)
Hi3516CV500CN.pdf (242.93 KB)
Hi3519V101.pdf (298.44 KB)
Hi3519AV100.pdf (343.87 KB)
Hi3559AV100.pdf (361.51 KB)
Hi3559CV100.pdf (350.73 KB)
zeshoufx| | 2020-8-20 08:51 | 只看该作者
谢谢分享【华为海思芯片方案开发技术经验总结】
梦爱琴所| | 2020-8-20 11:04 | 只看该作者
楼主这是要帮海思推广吗?可惜当下没货了。。先收藏,以后相信海思会挺过来的。
pleee| | 2020-8-21 10:29 | 只看该作者
供货有问题了,我们都不敢继续用海思了,现在转安霸或者用英伟达的了
maximQ820270087|  楼主 | 2020-8-30 10:17 | 只看该作者
目前这几款还有备货  可用两年内
123654789| | 2020-8-30 20:51 | 只看该作者
好好好顶顶顶
钓鱼大师| | 2020-9-8 17:37 | 只看该作者
川普要下台了,拜登说他当选就结束与中国的贸易战。
