求帮助 OK6410 USB烧写时无反应
165|0
喷水壶|  楼主 | 2018-9-5 11:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
按照手册操作TRANSMIT时无任何反应
DNW信息如下:
Reset by XnRESET[RSTSTAT:0x1]
VCO=1.064GHz
|  TE6410 USB OTG Downloader v0.1 (2009.12.22)  |
|  Forlinx embedded          www.witech.com.cn  |
ARMCLK: 532.00MHz  HCLKx2: 266.00MHz  HCLK: 133.00MHz  PCLK: 66.50MHz
VIC mode / Sync Mode
USB host is not connected yet.
Waiting for USB host connection.
Insert an OTG cable into the connector!
!!! USB host is connected !!!
- Bulk In EP : 1
- Bulk Out EP : 2
- Speed : High
- Op Mode : DMA mode
Download & Run is selected
USB PORT STATUS信息如下:
===== USB DEVICE STATUS =====
USB_CONFIGURATION_DESCRIPTOR
bLength = 0x9, decimal 9
bDescriptorType = 0x2 ( USB_CONFIGURATION_DESCRIPTOR_TYPE )
wTotalLength = 0x20, decimal 32
bNumInte**ces = 0x1, decimal 1
bConfigurationValue = 0x1, decimal 1
iConfiguration = 0x0, decimal 0
bmAttributes = 0xc0 ( ??? UNKNOWN!! )
MaxPower = 0x19, decimal 25
USB_INTE**CE_DESCRIPTOR #0
bLength = 0x9
bDescriptorType = 0x4 ( USB_INTE**CE_DESCRIPTOR_TYPE )
bInte**ceNumber = 0x0
bAlternateSetting = 0x0
bNumEndpoints = 0x2
bInte**ceClass = 0xff
bInte**ceSubClass = 0x0
bInte**ceProtocol = 0x0
bInte**ce = 0x0
USB_ENDPOINT_DESCRIPTOR for Pipe00
bLength = 0x7
bDescriptorType = 0x5 ( USB_ENDPOINT_DESCRIPTOR_TYPE )
bEndpointAddress= 0x81 ( INPUT )
bmAttributes= 0x2 ( USB_ENDPOINT_TYPE_BULK )
wMaxPacketSize= 0x200, decimal 512
bInterval = 0x0, decimal 0
USB_ENDPOINT_DESCRIPTOR for Pipe01
bLength = 0x7
bEndpointAddress= 0x2 ( OUTPUT )
不知道怎么回事,求帮助,怎么解决啊?
