Is a MOV using high registers (R8-R15) possible
178|0
社畜一枚|  楼主 | 2018-9-9 09:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The ARMv6-M Architecture Reference Manual section \"A6.7.40 MOV (register)\" on page A6-140 states that the T1 encoding of the MOV instruction is only available on the ARMv6-M architecture if both the source and destination register are from R0-R7. However arm-none-eabi-as assembles the instruction \"MOV r15, r14\" without any problems:
$ echo \'mov r15,r14\' | arm-none-eabi-as -march=armv6-m
$ arm-none-eabi-objdump -d a.out
0: 46f7 mov pc, lr
Also, this answer on stackoverflow states that it is possible to acces the high registers on the ARMv6-M architecture.
Could this be a mistake in the reference manual? Or am I reading it wrong?
