[技术问答]
如何在省电模式中,唤醒后但不进中断处理?
1136|3
uiint|  楼主 | 2024-5-28 20:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在进入省电模式之前,用户可以藉由呼叫下列函数
__disable_irq();
禁用 IRQ 处理,使得系统在唤醒之后,会接续执行进入省电模式的下一笔指令,而不会进入中断处理程序。
除此之外,用戶还需要注意以下几点 :
用户需要 __WFI 函數後面加上函數
      __ISB();
      清除管线预先抓取的指令,使得接续的指令能被正确的抓取并且执行。
写 ”1” 到 NVIC_ICPR 将对应的 IRQ 处理挂起清除。
将中断旗帜清除。
稳稳の幸福| | 2024-5-28 20:55 | 只看该作者
那唤醒后从哪儿开始执行?
jasontu| | 2024-5-30 09:32 | 只看该作者
#include <stdio.h>
#include "NuMicro.h"
/*  Function for System Entry to Power Down Mode                                                           */
void PowerDownFunction(void)
    /* Check if all the debug messages are finished */
    UART_WAIT_TX_EMPTY(UART0);
    /* Enter to Power-down mode */
    CLK_PowerDown();
        __ISB();
* @brief       GPIO PA/PB/PG/PH IRQ
* @param       None
* @return      None
* @details     The PA/PB/PG/PH default IRQ, declared in startup_M031Series.s.
void GPABGH_IRQHandler(void)
    volatile uint32_t temp;
    /* To check if PB.3 interrupt occurred */
    if(GPIO_GET_INT_FLAG(PB, BIT3))
        GPIO_CLR_INT_FLAG(PB, BIT3);
        printf("INTERRUPT PB.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PB interrupts */
        temp = PB->INTSRC;
        PB->INTSRC = temp;
        printf("Un-expected interrupts.\n");
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function                                              */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Lock protected registers */
    SYS_LockReg();
/* Init UART0                                                           */
void UART0_Init(void)
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
int main(void)
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU @ %d Hz\n", SystemCoreClock);
    printf("+-------------------------------------------------------+\n");
    printf("|    GPIO Power-Down and Wake-up by PB.3 Sample Code    |\n");
    printf("+-------------------------------------------------------+\n\n");
    /* Configure PB.3 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(PB, BIT3, GPIO_MODE_QUASI);
    GPIO_EnableInt(PB, 3, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPIO_PAPBPGPH_IRQn);
    /* Enable interrupt de-bounce function and select de-bounce sampling cycle time is 1024 clocks of LIRC clock */
    GPIO_SET_DEBOUNCE_TIME(GPIO_DBCTL_DBCLKSRC_LIRC, GPIO_DBCTL_DBCLKSEL_1024);
    GPIO_ENABLE_DEBOUNCE(PB, BIT3);
    /* Unlock protected registers before entering Power-down mode */
    SYS_UnlockReg();
    /* Waiting for PB.3 rising-edge interrupt event */
    while(1)
        printf("Enter to Power-Down. Wait PB.3 rising edge interrupt to wake up ...\n");
        __disable_irq();
        PowerDownFunction();
        printf("MAIN PB.3 INT occurred.\n");
                          NVIC_ClearPendingIRQ(GPIO_PAPBPGPH_IRQn);
        printf("System waken-up done.\n\n");
