[MCU]
msp430g2553 用捕获的方法测脉宽长度,但一直测的有问题,求救啊
295|0
两只袜子|  楼主 | 2020-12-3 09:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序如下:
#include "msp430g2553.h"
unsigned int start,end,overflow;
float num;
void main( void )
  WDTCTL = WDTPW + WDTHOLD;
  BCSCTL1 = CALBC1_8MHZ;
  DCOCTL = CALDCO_8MHZ;
  TA1CTL = TASSEL_1 + MC_2 + TAIE;
  TA1CCTL2 = CM_1 + CCIS_1 + CAP + CCIE + SCS;
  P2DIR |=BIT4;
  P2DIR &=~BIT5;
  P2SEL |=BIT5;
  _EINT();
  while(1);
#pragma vector = TIMER1_A1_VECTOR
__interrupt void Timer_A(void)
  switch(TA1IV)
  case 4:
         if(TA1CCTL2&CM0)
          start = TA1CCR2;
          TA1CCTL2 = CM_2 + CCIS_1 + CAP + CCIE + SCS;
          overflow = 0;
         else if(TA1CCTL2&CM1)
          end = TA1CCR2;
          num = (end  + overflow*65535 - start);
         break;
  case 10:
          overflow++;
          break;
  default:break;
