[MCU]
msp430f149测量PWM高电平的时间
365|2
继庐行者|  楼主 | 2020-12-14 17:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
msp430f149测量PWM高电平的时间,在1602液晶上显示出来,代码如下://MSP430F149 定时器A捕获功能测脉冲宽度
#include <msp430x14x.h>
#include "Config.h"
#include "1602.c"
#define  uint     unsigned int
#define  uchar    unsigned char
uint pwm_end;
uint time;
uint width;
//     键值显示程序
void LCD_DisplayKey(uint keynum)
  LCD_write_char(0x0a,1,0x30+(keynum/10000));
  LCD_write_char(0x0b,1,0x30+((keynum%10000)/1000));
  LCD_write_char(0x0c,1,0x30+(keynum%1000)/100);
  LCD_write_char(0x0d,1,0x30+ ((keynum%1000)%100)/10);
  LCD_write_char(0x0e,1,0x30+ (((keynum%1000)%100)%10)/1);
void LCD_DisplayKey1(uint keynum)
  LCD_write_char(0x01,1,0x30+(keynum/10000));
  LCD_write_char(0x02,1,0x30+((keynum%10000)/1000));
  LCD_write_char(0x03,1,0x30+(keynum%1000)/100);
  LCD_write_char(0x04,1,0x30+ ((keynum%1000)%100)/10);
  LCD_write_char(0x05,1,0x30+ (((keynum%1000)%100)%10)/1);
  LCD_write_char(0x06,1,0x75);
  LCD_write_char(0x07,1,0x73);
void main(void)
   WDT_Init();                         //看门狗设置
   Clock_Init();                       //系统时钟设置
   Port_init();                        //系统初始化,设置IO口属性
   delay_ms(100);                      //延时100ms
   LCD_init();                         //液晶参数初始化设置
   LCD_clear();                        //清屏
    P1DIR|=BIT1;
    P1SEL|=BIT1;   //捕获源为P1.1
    TACCTL0 =CM_3+SCS+CAP+CCIS_0+CCIE; //上升沿下降沿都同步捕获
    TACTL =TASSEL_2  + MC_2; //定时器计数开始 连续计数模式
    _EINT();          //开总中断
//   LPM0;           //低功耗模式
//   _NOP();         //不操作
    while(1)
         width = pwm_end;
         time=width/8;
         LCD_DisplayKey(width);
         LCD_DisplayKey1(time);
/******定时器TA的CCR1的中断 用于检测脉冲上升沿和下降沿******/
#pragma vector=TIMERA1_VECTOR
__interrupt void Timer_A1(void)
  switch(TAIV)
            case 0x02:break;
                        case 0x04:
            if(TACCTL0 & CCI )// if(CCI==1)
                           TACTL=TACLR;   //定时器清零
            else
              pwm_end = TACCR0;
            break;
                        case 0x0A:break;
            default:
            break;
          LPM0_EXIT;
大家帮忙看看是那个地方出问题了
zhangmangui| | 2020-12-14 22:35 | 只看该作者
看看有捕获功能的引脚吗  这个最准确
继庐行者 2020-12-15 08:56 回复TA
捕获引脚是P1.1
