[资料分享]
LT8668SX-DP+HDMI_to_MIPI+EDPX+HDMI
1871|3
JLKJ18338421851|  楼主 | 2022-3-24 09:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. 一般的描述
LT8668SX可以配置工作在HDMI2.1标准下,最大8Gb/s的数据速率,允许8Kx4K60Hz的最高分辨率与DSC或8Kx4K30Hz。
2. LT8668SX还可以配置为工作在DP1.4与高达8.1Gb/s的数据速率,以允许8Kx4K60Hz的最高分辨率与DSC或8Kx4K30Hz。
对于LVDS输出,LT8668SX可配置为单端口、双端口或四端口LVDS,1个高速时钟通道,3~5个高速数据通道,总带宽可达24Gbps。
对于MIPI输出,LT8668SX可以配置为单端口、双端口或四端口MIPI,使用D-PHY高速数据通道,最大工作在2.5Gb/s/lane,可支持总带宽高达40Gbps;或使用C-PHY支持5.7Gb/s/lane,可支持总带宽高达68.4Gbps。
对于eDP输出,它由8个数据通道组成,支持RBR(1.62Gbps)、HBR(2.7Gbps)和HBR2 (5.4Gbps)链路速度。内置的可选SSC功能减少电磁干扰影响有关的系统应用。
eDPx输出由8条数据通道组成,每条数据通道最大运行速度为3Gb/s,可支持4K@60Hz。
LT8668SX内部集成了8位OCM和SPI闪存(堆叠模)来运行程序。LT8668SX也支持软件在线升级。
LT8668SX采用先进的CMOS工艺制作,在12mmx12mm BGA288封装中实现。 该封装符合RoHS标准,可在-40°C至+85°C范围内工作。
2.特性
•HDMI2.1接收机
•USB c型
•DP1.4接收机
•HDMI2.1发射机
•DP1.4发射机
•单/双/四端口LVDS发射器
•单/双/四端口MIPIDSI/CSI发射器
•eDP/eDPx发射机
•LPDDR 3/4控制器
•杂项
3.应用程序
•移动系统
•手机、PAD/平板电脑
•显示
•AR/虚拟现实
1. General Description
LT8668SX can be configured to work under HDMI2.1 standard with maximum 8Gb/s data rate to allow for the highest resolutions of 8Kx4K 60Hz with DSC or 8Kx4K 30Hz.
LT8668SX also can be configured to work under DP1.4 with up to 8.1Gb/s data rate to allow for the highest resolutions of 8Kx4K 60Hz with DSC or 8Kx4K 30Hz.
For LVDS output, LT8668SX can be configured as single-port , dual-port or four-port LVDS with 1 high- speed clock lane, and 3~5 high-speed data lanes, which can support a total bandwidth up to 24Gbps.
For MIPI output, LT8668SX can be configured as single-port , dual-port or four-port MIPI with high-speed data lanes operating at maximum 2.5Gb/s/lane with D-PHY, which can support a total bandwidth of up to 40Gbps, Or support 5.7Gb/s/lane with C-PHY, which can support a total bandwidth of up to 68.4Gbps.
For eDP output, it consists of 8 data lanes, supporting RBR (1.62Gbps), HBR (2.7Gbps) and HBR2 (5.4Gbps) link speeds. The build-in optional SSC function reduces EMI effect on EMI-concerned system application.
For eDPx output, it consists of 8 data lanes, with operating at maximum 3Gb/s per lane, which can support 4K@60Hz.
LT8668SX internally integrates an 8-bit OCM and SPI flash memory (stacked die) to run program. Online software upgrade is also supported for LT8668SX.
LT8668SX is fabricated in advanced CMOS process and implemented in 12mmx12mm BGA288 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• HDMI2.1 receiver
• USB Type-C
• DP1.4 Receiver
• HDMI2.1 Transmitter
• DP1.4 Transmitter
• Single/Dual/Four-Port LVDS Transmitter
• Single/Dual/Four-Port MIPI® DSI/CSI Transmitter
• eDP/eDPx Transmitter
• LPDDR 3/4 Controllter
• Miscellaneous
3.  Applications
• Mobile system
• Cellular handsets, PAD/Tablets
• Display
• AR/VR
九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!Email:bcxu.jl@foxmail.com
JLKJ18338421851|  楼主 | 2022-3-26 15:14 | 只看该作者
龙讯一级代理,正品原装,假一罚十,量大从优,深圳市九黎科技有限公司
lixun00| | 2022-3-30 09:27 | 只看该作者
不知道原厂怎么管控,找代理要资料一概没有,遮遮掩掩,付款开发什么的,很积极
JLKJ18338421851|  楼主 | 2022-4-1 11:43 | 只看该作者
因为代理也得听原厂的啊
