ROS2在QNX aarch64环境下编译踩坑笔记:unique_identifier_msgs
91|4
In file included from /home/kevin/ros2_galactic/env/lib/python3.11/site-packages/numpy/core/include/numpy/ndarraytypes.h:5,
                 from /home/kevin/ros2_galactic/env/lib/python3.11/site-packages/numpy/core/include/numpy/ndarrayobject.h:12,
                 from /home/kevin/ros2_galactic/build/aarch64le/unique_identifier_msgs/rosidl_generator_py/unique_identifier_msgs/msg/_uuid_s.c:11:
/home/kevin/ros2_galactic/env/lib/python3.11/site-packages/numpy/core/include/numpy/npy_endian.h:13:14: fatal error: endian.h: No such file or directory
     #include <endian.h>
keer_zu|  楼主 | 2024-5-9 13:33 | 只看该作者
keer_zu|  楼主 | 2024-5-9 14:28 | 只看该作者
在cmakelist.txt中添加路径:
include_directories(/home/kevin/qnx710/target/qnx7/usr/include/devs/include_aarch64/machine/)
keer_zu|  楼主 | 2024-5-9 14:29 | 只看该作者
还报错。
以下是部分:
keer_zu|  楼主 | 2024-5-9 14:32 | 只看该作者
于是:
remove_definitions(D__WAIT_H_INCLUDED)
remove_definitions(D_SIGNAL_H_INCLUDED)
