帮我看看我的初始化程序哪里有问题!
1347|0
ymsf21ic|  楼主 | 2007-3-3 22:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的程序是5510串口初始化aic11,要求初始完成后音频信号能直通。
我的问题是
  1。串口回环能够通过(不考虑aic11):即 写入数据到dxr后,在drr中能正确的收到,但是在dx管脚用示波器却测不到。
  2。取消回环,初始化aic11不能成功,数据不能写入到aic11的寄存器,如果写入成功的话,aic11的输出时钟会按照配制的要求改变,但是现在测得的情况是没有改变。且程序停在while (!(*(volatile ioport int*)McBSP0_SPCR1_0 & 0x2)){};rrdy始终是为0。
  下面是主要部分的源代码,希望大家帮我看看问题出在哪里!谢谢!!
void init_board(void)
  *(volatile ioport int*)McBSP0_RCR1_0=0x0040;
  *(volatile ioport int*)McBSP0_RCR2_0=0x0002;
  *(volatile ioport int*)McBSP0_XCR1_0=0x0040;
  *(volatile ioport int*)McBSP0_XCR2_0=0x0002;
  *(volatile ioport int*)McBSP0_SRGR1_0=0x0101;
  *(volatile ioport int*)McBSP0_SRGR2_0=0x200f;
  *(volatile ioport int*)McBSP0_PCR0=0x0a00;
  *(volatile ioport int*)McBSP0_SPCR2_0=0x00c1;
*(volatile ioport int*)McBSP0_SPCR1_0=0x0001;
void mcbsp0_write(int out_data)     //function for writing
  *(volatile ioport int*)McBSP0_DXR1_0 = out_data;
int mcbsp0_read()         //function for reading
int tp;
tp=*(volatile ioport int*)McBSP0_DRR1_0;
return tp;
void init_aic11()
int val[8]={0x0001,0x0200,0x0001,0x0402,0x0001,0x0600,0x0001,0x0800};
    int i;
    for(i=1;i<8;i++)
    while(!(*(volatile ioport int*)McBSP0_SPCR2_0 & 0x2)){};
    mcbsp0_write(val);
#include "io.h"
#include <stdio.h>
void main()
    int xrdy,rrdy,i=0,err=0,sam[N],rcv[N],xx;
    int sample;
    init_board();
    init_aic11();
  while(1)
   sample = mcbsp0_read();
   while (!(*(volatile ioport int*)McBSP0_SPCR2_0 & 0x2)){};
   mcbsp0_write(sample&0xfffe);
