有的flash的0x555、0x2aa写命令不在意A15是高还是低,这个要看datasheet。<br /><br />Address format A14-A0 (Hex):<br />Address A15 is “Don’t Care” for the Command sequence for SST39LF/VF512.<br />Address A15 and A16 are “Don’t Care” for the Command sequence for SST39LF/VF010.<br />Address A15, A16 and A17 are “Don’t Care” for the Command sequence for SST39LF/VF020.<br />Address A15, A16, A17 and A18 are “Don’t Care” for the Command sequence for SST39LF/VF040.<br /><br /><br />SST39LF/VF200A SST39LF/VF400A SST39LF/VF800A:<br />Address format A14-A0 (Hex), Addresses AMS-A15 can be VIL or VIH, but no other value, for the Command sequence.<br />
