STC12C2052AD关于AD转换求助!
3888|4
 楼主| baobei 发表于 2008-5-19 10:12 | 显示全部楼层 |阅读模式
程序如下,启动AD转换,结果通过串口送出,第一次转换结果是正确的,以后的数据全是错误的。
// ad test
#include <reg52.h>
/*A/D  SFR*/
//sfr ADC_LOW2  = 0xBE;
sfr ADC_CONTR = 0xC5;
sfr ADC_DATA  = 0xC6;
//sfr CLK_DIV   = 0xC7;
sfr P1M0            = 0x91;
sfr P1M1            = 0x92;
sbit led=P1^7;
sbit led2=P1^6;
unsigned char rec;
void delay(unsigned int i)
    while(i--);
    return;
void ad_init(void)
    ADC_CONTR = ADC_CONTR|0x80;            //启动AD转换电源
    delay(3000);                                            //延时大于1ms,使电源稳定
    P1M0 = P1M0|0x04;                                //00000100,设置P1.2为开漏
    P1M1 = P1M1|0x04;
    ADC_CONTR = ADC_CONTR|0xE2;            //11100010,设置P1.2为AD输入通道
    delay(600);                                            //切换AD通道后,延时200us,如果输入信号电压的内阻小于10K,可不用延时
void set_nor(void)
    P1M0 = P1M0|0xfb;                                //11111011,设置P1.2为NORMAL模式
    P1M1 = P1M1|0xfb;
void start_ad(void)
    ADC_DATA = 0;
    ADC_CONTR = ADC_CONTR|0x08;            //00001000,启动AD转换
void stop_ad(void)
    ADC_CONTR = ADC_CONTR|0xef;            //11100111,停止AD转换,并清除AD FLAG
bit is_ad_ok(void)
    unsigned char tt;
    tt = ADC_CONTR;
    if(tt&0x10==1)
        return(1);
    else
        return(0);
void sendbyte(unsigned char dat)
    SBUF = dat;
    while(TI==0);
    TI = 0;
void uart(void) interrupt 4
    if(RI)
        RI = 0;
        rec = SBUF;
    if(TI)
        TI = 0;
void uartinit(void)
    TMOD = 0x21;
    TL1 = 0xFa;
    TH1 = 0xFa;
    SCON = 0x50;
    PCON = 0x00;
    TR1 = 1;
    ES = 1;
    //EA = 1;
void ad(void)
    ad_init();
    start_ad();
    delay(50000);
    sendbyte(ADC_DATA);
    stop_ad();
    set_nor();
void main(void)
    unsigned char i;
    uartinit();
    sendbyte(0x12);
    ad_init();
    start_ad();
    delay(50000);
    sendbyte(ADC_DATA);
    stop_ad();
    set_nor();
    while(1)
        led = 0;
        if(rec==0x11)
            //sendbyte(i++);
            led2 = !led2;
            rec = 0;
        ad();
        delay(50000);
        led = 1;
        delay(50000);
 楼主| baobei 发表于 2008-5-19 11:33 | 显示全部楼层
姚工不给支持,没法子啊!
STC的技术支持,一般般.
 楼主| baobei 发表于 2008-5-19 13:59 | 显示全部楼层
符号错了
找到错误了,
void stop_ad(void)
应为
void stop_ad(void)
    ADC_CONTR = ADC_CONTR&0xef;            //11100111,停止AD转换,并清除AD FLAG
符号错了
gdjmlj 发表于 2008-6-17 22:47 | 显示全部楼层
stc12c2052ad
suizhouxh 发表于 2008-12-8 13:55 | 显示全部楼层
吸收下
谢谢!!参考下
