28035烧写flash
7672|12
 楼主| blueskycyh 发表于 2013-7-26 23:03 | 显示全部楼层 |阅读模式
用CCSV5.3开发28035,想要烧写flash,已将cmd文件改成可烧写的,点DEBUG弹出的窗口显示已经擦出和烧写flash了,也可以调试,但掉电后,程序好像就没有了。有没有哪位用过烧写flash的,可以指点一下啊
dirtwillfly 发表于 2013-7-27 10:30 | 显示全部楼层
TMS320X28035是TI公司2009年新推出的60M控制芯片,其烧写过程如下:
1.使用TI官方CMD文件F28035.CMD,和烧写有关的语句为:
RAML0 : origin = 0x008000, length = 0x000800
FLASHD : origin = 0x3F0000, length = 0x002000
ramfuncs : LOAD = FLASHD,
RUN = RAML0,
LOAD_START(_RamfuncsLoadStart),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
PAGE = 0
2.在工程中添加DSP2803x_MemCopy.c文件,内容如下:
#include "DSP2803x_Device.h"
void MemCopy(Uint16 *SourceAddr, Uint16* SourceEndAddr, Uint16* DestAddr)
while(SourceAddr < SourceEndAddr)
*DestAddr++ = *SourceAddr++;
return;
3.在DSP2803x_SysCtrl.c文件中添加如下语句:
#pragma CODE_SECTION(InitFlash, "ramfuncs");
void InitFlash(void)
EALLOW;
//Enable Flash Pipeline mode to improve performance
//of code executed from Flash.
FlashRegs.FOPT.bit.ENPIPE = 1;
// CAUTION
//Minimum waitstates required for the flash operating
//at a given CPU rate must be characterized by TI.
//Refer to the datasheet for the latest information.
//Set the Paged Waitstate for the Flash
FlashRegs.FBANKWAIT.bit.PAGEWAIT = 2;
//Set the Random Waitstate for the Flash
FlashRegs.FBANKWAIT.bit.RANDWAIT = 2;
//Set the Waitstate for the OTP
FlashRegs.FOTPWAIT.bit.OTPWAIT = 2;
// CAUTION
//ONLY THE DEFAULT VALUE FOR THESE 2 REGISTERS SHOULD BE USED
FlashRegs.FSTDBYWAIT.bit.STDBYWAIT = 0x01FF;
FlashRegs.FACTIVEWAIT.bit.ACTIVEWAIT = 0x01FF;
EDIS;
//Force a pipeline flush to ensure that the write to
//the last register configured occurs before returning.
asm(" RPT #7 || NOP");
4.在main()函数之前定义三个变量:
extern Uint16 RamfuncsLoadStart;
extern Uint16 RamfuncsLoadEnd;
extern Uint16 RamfuncsRunStart;
5.在main()函数初始化系统以后增加如下语句:
MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart);
InitFlash();
6.在CCS中点Tools>F28xx on-Chip Flash Programmer>Execute Pperation 完成烧写
评分
参与人数 1威望 +1 收起 理由
blueskycyh + 1 ffgfgf
查看全部评分
 楼主| blueskycyh 发表于 2013-7-28 22:51 | 显示全部楼层
1.使用TI官方CMD文件F28035.CMD,和烧 ...
版主好,前边的5步都做了,但cs5.3没有“ Tools>F28xx on-Chip Flash Programmer>Execute Pperation” 这个菜单哦,
dirtwillfly 发表于 2013-7-29 15:01 | 显示全部楼层
版主好,前边的5步都做了,但cs5.3没有“ Tools>F28xx on-Chip Flash Programmer>Execute Pperation” 这 ...
在CCS debug perspective中可以找到tools工具选项。
dontium 发表于 2013-7-30 11:36 | 显示全部楼层
把你产生的MAP文件帖上来看看
 楼主| blueskycyh 发表于 2013-7-31 23:39 | 显示全部楼层
把你产生的MAP文件帖上来看看
map文件在附件中
dontium 发表于 2013-8-1 15:52 | 显示全部楼层
map文件在附件中
从你的MAP文件上看,没有发现错误。
或者某些设置不正常吧。
可以在属性-->> DEBUG -- >> FLASH SETTING那里看看,或者仿真器拨掉后再看看能不能运行 。
我写有个帖子《在FLASH里运行》(不在二姨家),你可以参考一下。
 楼主| blueskycyh 发表于 2013-8-13 21:43 | 显示全部楼层
从你的MAP文件上看,没有发现错误。
或者某些设置不正常吧。
试了还是不行。点DEBUG后,能看到在操作flash,
应该是烧进去了。但只能点启动按钮才能运行
掉电之后重新上电,程序不会运行。
 楼主| blueskycyh 发表于 2013-8-31 23:17 | 显示全部楼层
在TI的技术在线找到了答案,原来是工程中缺少了一个DSP2803x_CodeStartBranch.asm ,这个文件是boot to flash需要的文件。
评分
参与人数 1威望 +1 收起 理由
dirtwillfly + 1 赞一个!
查看全部评分
 楼主| blueskycyh 发表于 2013-9-1 11:10 | 显示全部楼层
为啥结贴提示
海獭小静 发表于 2017-7-7 11:00 | 显示全部楼层
我的下载了  我单步调试到MemCopy就会有错误提示,程序完全不运行,但是编译又没有任何错误
iamaiqiyi 发表于 2017-7-7 23:29 | 显示全部楼层
现在有很多的开发板可以抄写。
iamaiqiyi 发表于 2017-7-7 23:32 | 显示全部楼层
参考别人的 硬件电路实现以下。
