[嵌入式linux]
NFS挂载文件系统出现nfs: server **** not responding, still tryin
1258|3
1、控制台输出信息
IP-Config: Complete:
     device=eth0, addr=192.168.0.104, mask=255.255.255.0, gw=192.168.0.1,
     host=192.168.0.104, domain=, nis-domain=(none),
     bootserver=192.168.0.107, rootserver=192.168.0.107, rootpath=
Root-NFS: TCP
Root-NFS: Mounting /home/radionfs on server 192.168.0.107 as root
Root-NFS:     rsize = 1024, wsize = 1024, timeo = 0, retrans = 0
Root-NFS:     acreg (min,max) = (3,60), acdir (min,max) = (30,60)
Root-NFS:     nfsd port = -1, mountd port = 0, flags = 000002c0
Root-NFS: ZZQ NFS_MOUNT_VER3
Looking up port of RPC 100003/3 on 192.168.0.107
eth0: link up (100/Full)
Root-NFS: Portmapper on server returned 2049 as nfsd port
Looking up port of RPC 100005/3 on 192.168.0.107
Root-NFS: mountd port is 39392
Root-NFS: zzq1
Root-NFS: zzq2
Root-NFS: zzq3
Root-NFS: zzq4
Root-NFS: zzq5
VFS: Mounted root (nfs filesystem) on device 0:12.
Freeing init memory: 128K
2、wireshark抓包信息
抓包显示:服务器发出的数据包为1222 大于客户端的1024
3、客户端设置:
ipaddr=192.168.0.104
bootcmd=tftp 72000000 uImage ;bootm 0x72000000
serverip=192.168.0.107
bootargs=mem=64M console=ttyS0 115200 root=/dev/nfs rw nfsroot=192.168.0.107:/home/radionfs,rsize=1024,wsize=1024,nfsvers=3,proto=tcp
ip=192.168.0.104:192.168.0.107:192.168.0.1:255.255.255.0::eth0:off
请教:  NFS挂载失败的原因?我使用的fedora10,   内核文件使用为:linux-2.6.30
是否是因为NFS服务器发送的数据包大小过大,导致客户端无法接收?
那么怎样将NFS服务器设置为客户端需要的数据包大小?
zhenqi2008|  楼主 | 2014-7-24 08:34 | 只看该作者
终于自己找到答案了 修改下 服务器的MTU值 就可以稳定下载了
HORSE7812| | 2014-12-20 09:30 | 只看该作者
好帖,mark
