PMS131/PMC131 输出2路PWM做同步升压,时序参考
1630|1
工控秀才|  楼主 | 2014-8-14 18:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有需要的可以联系我要压缩包,谢谢。
//*****         PMC/PMS131 Peocessor Application Example Project                 *****
//        Project Name :: 2-PWM out
//      Version      :: V0.0
//        Module Name  ::
//        Abstract     :: PMC131/PMS131
//        Environment:
//                PADAUK FPPA(TM) IDE Tool Version : 0.63
//        Revision History:
//                Agu. 14, 2014        Raker.Yang  Created
//  Contact  me:
//  Tel: 135 1077 9653 ; QQ: 595 142 970
// Copyright (C) 2014 by JINRUN Electronic Technology Co. Ltd. All rights reserved.
#include        "extern.h"
word    t16_cnt;
word    g_word;
byte    timer_10ms_cnt;
byte    pwm2b_bak;
byte    pwm3b_bak;
T16_Base        EQU             20000
void    t16_init(void)
        word   t16_index;
        T16M  = 0x2f;
        t16_index = 0;
        stt16  t16_index;
void        FPPA0 (void)
        .ADJUST_IC        SYSCLK=IHRC/2, IHRC=16MHz, VDD=5V, Bandgap=Off
        PA = 0;
        PB = 0;
        PAC = 0xff;
        timer_10ms_cnt = 0;
        PBC = 0xFF;
        $ PADIER 0xF9;
        $ PBDIER 0xFF;
  t16_init();
        TM2S = 0B_1_00_00000;
        TM3S = 0B_1_00_00000;
        pwm2b_bak = 9;
        pwm3b_bak = 1;
        tm2b  = pwm2b_bak;
        tm3b  = pwm3b_bak;
        TM2C = 0B0010_10_1_0;        //PB4
        TM3C = 0B0010_01_1_0;        //PB5
        while (1)
                 .wdreset;
                ldt16   g_word;
                a     = (g_word - t16_cnt) >> 8;
                if(a < 0x80)
//                tog   VLED1_OUT;
                  t16_cnt += T16_Base;
                  if(timer_10ms_cnt < 100)
                          timer_10ms_cnt++;
                  else
                          timer_10ms_cnt = 0;
                          if(pwm2b_bak < 60)
                                   pwm2b_bak++;
                                   pwm3b_bak++;
                          else
                 pwm2b_bak = 9;
                 pwm3b_bak = 1;
              tm2b  = pwm2b_bak;
              tm3b  = pwm3b_bak;
董自祝| | 2015-10-30 16:29 | 只看该作者
支持一下,最近在学习应广MCU,请多多指教
个人签名:杨R QQ:595142970, 群:72958773 T: 1351077九6五3,微公号,应广单片机 https://shop150007363.taobao.com
38
