[应用方案] 基于新唐M451的串口FIFO中断状态机接收的DMX512的方案
7355|25
 楼主| 缥缈九哥 发表于 2014-10-7 00:15 | 显示全部楼层 |阅读模式
利用国庆假期,写了一个简单方案。用了串口FIFO中断和状态机,详情请看源码:
#define DMXBUFMAX        513
typedef enum {dmxIDLE=1,dmxBREAK,dmxSTART,dmxSLOT,dmxTOUT,dmxEND} status_t;
typedef  struct
        status_t status;
        uint32_t index;
        uint32_t length;
        uint8_t  slot[DMXBUFMAX];
}dmx_t; dmx_t dmxRx,dmxTx;
/* Define functions prototype        */
void DMX512_Transmit(const uint8_t slot0, const uint32_t address, const uint32_t length);
void DMX_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
        /* Reset IP */
    SYS_ResetModule(UART0_RST);
        /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD(PD.0) and TXD(PD.1) */
//    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
//  SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
        /* Set PD multi-function pins for UART0 RXD(PD.6) and TXD(PD.1) */
        SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
        SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Init UART        */
    UART_Open(UART0, 250000);
        /* Set Data Format*/ /* Only need 8 M 2 */
        UART_SetLine_Config(UART0, 0, UART_WORD_LEN_8, UART_PARITY_MARK, UART_STOP_BIT_2);
        /* Set RX Trigger Level = 14 */
        UART0->FIFO = (UART0->FIFO & (~ UART_FIFO_RFITL_Msk)) | UART_FIFO_RFITL_14BYTES;
        /* Set Timeout time 16 bit-time */
        UART_SetTimeoutCnt(UART0,16);
#if 0
        /* Set RTS Trigger Level */
        UART0->MODEM |= UART_RTS_IS_HIGH_LEV_TRG;
        UART0->FIFO = (UART0->FIFO &~ UART_FIFO_RTSTRGLV_Msk) | UART_FIFO_RTSTRGLV_14BYTES;
    /* Enable RTS and CTS autoflow control */
        UART0->INTEN |= UART_INTEN_ATORTSEN_Msk | UART_INTEN_ATOCTSEN_Msk;
#endif
        /* Enable RDA\RLS\RTO Interrupt  */
        UART_EnableInt(UART0, (UART_INTEN_RDAIEN_Msk | UART_INTEN_RLSIEN_Msk | UART_INTEN_RXTOIEN_Msk));
    /* Disable Interrupt */
//        UART_DisableInt(UART0, (UART_INTEN_RDAIEN_Msk | UART_INTEN_RLSIEN_Msk | UART_INTEN_RXTOIEN_Msk));
        dmxRx.status=dmxIDLE;dmxRx.length=dmxRx.index=0;
        /* Lock protected registers */
    SYS_LockReg();
/* ISR to handle UART Channel 0 interrupt event                                                            */
void UART0_IRQHandler(void)
        uint32_t u32IntSts=UART0->INTSTS;
        if(dmxRx.index>=DMXBUFMAX){dmxRx.index=0;}
        if(u32IntSts & UART_INTSTS_RLSINT_Msk) // UART_INTSTS_RLSIF_Msk
                if(dmxRx.status==dmxIDLE){dmxRx.status=dmxBREAK;}
                UART0->FIFOSTS |= UART_FIFOSTS_ADDRDETF_Msk | UART_FIFOSTS_PEF_Msk | UART_FIFOSTS_FEF_Msk | UART_FIFOSTS_BIF_Msk;
                uint8_t tmp = UART_READ(UART0);
                if(dmxRx.status==dmxBREAK){dmxRx.status=dmxSLOT;dmxRx.length=dmxRx.index=0;}
    if(u32IntSts & UART_INTSTS_RDAINT_Msk) //UART_INTSTS_RDAIF_Msk
                for(uint32_t i=0;i<13;i++)
                        uint8_t tmp=UART_READ(UART0);
                        if(dmxRx.status==dmxSLOT){dmxRx.slot[dmxRx.index++]=tmp;}
        if(u32IntSts & UART_INTSTS_RXTOINT_Msk) //UART_INTSTS_RXTOIF_Msk
                if(dmxRx.status==dmxSLOT){dmxRx.status=dmxTOUT;}
                while(UART0->FIFOSTS & UART_FIFOSTS_RXPTR_Msk)
                        if(dmxRx.status==dmxTOUT){dmxRx.slot[dmxRx.index++]=tmp;}
        if((dmxRx.status==dmxTOUT)||(dmxRx.index>=DMXBUFMAX))
        {dmxRx.length=dmxRx.index;dmxRx.status=dmxEND;dmxRx.index=0;}
        if(u32IntSts & UART_INTSTS_THREINT_Msk)  // UART_INTSTS_THREIF_Msk
    {printf("THRE\n\r");}
/*  DMX512 Transmit        */
        uint8_t *buf=(uint8_t *)address;uint32_t len=length;
#if 0
        UART0->FUNCSEL = UART_FUNCSEL_LIN;
        UART0->ALTCTL |= UART_ALTCTL_LINTXEN_Msk;
//        UART0->LINCTL &= UART_LINCTL_HSEL_Msk;
//        UART0->LINCTL |= (UART_LINCTL_HSEL_Msk & 0x01);
        UART0->ALTCTL &= ~UART_ALTCTL_BRKFL_Msk;
        UART0->ALTCTL |= (UART_ALTCTL_BRKFL_Msk & 0x0f);
#else
        /* DMX512 “SPACE” for BREAK                          88us         */
        UART0->LINE |= UART_LINE_BCB_Msk;
        CLK_SysTickDelay(88);
        /* DMX512 “MARK” After BREAK (MAB)          8us         */
        UART0->LINE &= ~UART_LINE_BCB_Msk;
        CLK_SysTickDelay(8);
#endif
        /* DMX512 START CODE (Slot 0 Data)                1byte         */
        UART_WRITE(UART0,slot0);
        /* DMX512 SLOT 1-512 DATA (Maximum 512) 512 bytes */
        UART_Write(UART0,buf,len);
/* MAIN function        */
int dmx512_test(void)
        uint32_t delay=0;
    /* Init System, IP clock and multi-function I/O */
    DMX_Init();
        DBG_PRINTF("\n\r\n\r");
        DBG_PRINTF("*** 9G-NUC451 V3.00 Build by yuanxihua@21cn.com on ("__DATE__ " - " __TIME__ ")\n\r");
        DBG_PRINTF("*** 9G-NUC451 V3.00 Rebooting ...\n\r\n\r");
    /* SAMPLE CODE        */
        uint8_t buf[512];for(uint32_t i=0;i<sizeof(buf);i++){buf=i>>1;}
//        printf("Transmission Test:\n\r");
//        while(1) {UART_Write(UART0,buf,sizeof(buf));CLK_SysTickDelay(500000);}
    while(1)
                if(delay>10000)
                        DMX512_Transmit(0,(uint32_t)&buf[0],sizeof(buf));
                        delay=0;
                if(dmxRx.status==dmxEND)
                        printf("DMX:");for(uint32_t i=0;i<dmxRx.length;i++){if(i%16==0){printf("\n\r");}printf("%02x ",dmxRx.slot);}
                        DMX512_Transmit(dmxRx.slot[0],(uint32_t)&dmxRx.slot[1],dmxRx.length-1);
                        dmxRx.status=dmxIDLE;dmxRx.length=0;
                CLK_SysTickDelay(100);delay++;
gaoyang9992006 发表于 2014-10-8 16:28 | 显示全部楼层
这程序写的出神入化,我差点没看懂。顶起。
598330983 发表于 2014-10-15 19:49 | 显示全部楼层
九哥的这种精神值得学习,顶起
gxliu08 发表于 2014-10-15 20:20 | 显示全部楼层
学习学习,谢谢分享
从小木丁丁 发表于 2014-10-15 21:24 | 显示全部楼层
顶起
九哥果然厉害,赞一个
你这是拍马屁呢还是拍马屁呢
从小木丁丁 发表于 2014-10-15 21:25 | 显示全部楼层
九哥的这种精神值得学习,顶起
值得学习,值得鼓励
学习学习,谢谢分享
我们要好好跟九哥学习
bobde163 发表于 2014-10-15 22:42 | 显示全部楼层
得好好看一下
 楼主| 缥缈九哥 发表于 2014-10-30 01:08 | 显示全部楼层
顶起。
 楼主| 缥缈九哥 发表于 2014-11-3 14:24 | 显示全部楼层
又沉下去了。
kulas 发表于 2016-1-19 20:31 | 显示全部楼层
为九哥顶起
天灵灵地灵灵 发表于 2016-1-20 21:48 | 显示全部楼层
250000是什么?波特率还是主频?
598330983 发表于 2016-1-20 22:22 | 显示全部楼层
这个类型好复杂的说。
Tennasi 发表于 2016-1-21 08:53 | 显示全部楼层
波特率最高能设为多少呢?
huangcunxiake 发表于 2016-1-25 22:39 | 显示全部楼层
FIFO( First In First Out)简单说就是指先进先出。由于微电子技术的飞速发展,新一代FIFO芯片容量越来越大,体积越来越小,价格越来越便宜。
598330983 发表于 2016-1-26 09:54 | 显示全部楼层
如果程序能分块写就好了,就想那个Labview一样,但是还是C,只不过可以封装到一个图形里,然后提供接口。。。
稳稳の幸福 发表于 2016-1-26 20:56 | 显示全部楼层
是25MH的晶振使用吗?
zhuotuzi 发表于 2016-1-27 14:10 | 显示全部楼层
这程序写的出神入化,我差点没看懂。
个人签名:童时不懂世事艰,笑谈学成锦衣还。岁月无声已先过,男儿有泪空自弹。    莫待沾霜愁上发,须嬴吐气喜开颜。拼搏半年誓如愿,不到长城心不甘。
67
