[技术问答] m451开发板 7段数码管点不亮
3846|8
 楼主| FBgg 发表于 2014-10-31 18:38 | 显示全部楼层 |阅读模式
初学者,昨天刚得了块板子,还不会用,求牛牛们指教。
用的是BSP下面的例子
C:\Nuvoton\BSP Library\M451SeriesBSP_CMSIS_v3.00.003\SampleCode\NuEdu\Smpl_Basic01_7_Segment
不太清楚问题在哪里,希望得到大家指导,谢谢。
下面是按照网上说明对keil进行的设置。
Smpl_Basic01_7_Segment主程序
* @file     main.c
* @version  V3.00
* $Revision: 2 $
* $Date: 14/08/12 6:35p $
* @brief    Demonstrate how to set GPIO pin mode and use pin data input/output control.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include "stdio.h"
#include "M451Series.h"
#include "NuEdu-Basic01.h"
#define PLL_CLOCK       72000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD(PD.6) and TXD(PD.1) */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
void UART0_Init()
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
    int i, j;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU @ %dHz\n", SystemCoreClock);
    printf("Seven Segment Test\n\r");
    Open_Seven_Segment();
    while(1)
        for(i = 0; i < 9; i++)
            Show_Seven_Segment(i, 1);
            for(j = 0; j < 500; j++)
                CLK_SysTickDelay(1000);
            Show_Seven_Segment(i, 2);
 楼主| FBgg 发表于 2014-10-31 22:11 | 显示全部楼层
自己keil没整明白...囧,已经可以了。
通宵敲代码 发表于 2014-11-1 22:25 | 显示全部楼层
楼主多做总结!
这是一个很基本的问题!
niuyaliang 发表于 2014-11-4 14:01 | 显示全部楼层
慢慢的来!
gaoyang9992006 发表于 2014-11-6 23:17 | 显示全部楼层
楼主先控制一个LED灯试试看
mintspring 发表于 2014-11-12 22:47 来自手机 | 显示全部楼层
感觉好麻烦啊
chansoncc 发表于 2014-11-17 16:10 | 显示全部楼层
为毛我现在在nuvoton 这个官网上下的 M451Series_BSP_CMSIS_V3.00.003.zip 这个包没有楼主说的那个\NuEdu\下的例程啊,组天刚得到一块451板,正想一一验证下basic板的各个功能呢,但没有例程可参考。
要不楼主共享一个?谢谢!
 楼主| FBgg 发表于 2014-11-17 16:17 | 显示全部楼层
为毛我现在在nuvoton 这个官网上下的 M451Series_BSP_CMSIS_V3.00.003.zip 这个包没有楼主说的那个\NuEdu\ ...
留个email: 我发给你.
chansoncc 发表于 2014-11-17 16:26 | 显示全部楼层
留个email: 我发给你.
恩!万分感谢! chansoncc@sohu.com   或者  78814379@qq.com
