[PCB]
ORCAD 生成PCB netlister 时出现的报警信息 !
1369|3
xclfang|  楼主 | 2014-11-8 14:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
coollest| | 2014-11-8 16:03 | 只看该作者
这个提示是告诉你请查看日志
xclfang|  楼主 | 2014-11-8 19:32 | 只看该作者
The following 1 points have been identified as net connectivity change points from the last operation
(190.50, 33.02)
The following 2 points have been identified as net connectivity change points from the last operation
(208.28, 45.72)
(203.20, 45.72)
(208.28, 33.02)
(190.50, 58.42)
(200.66, 58.42)
(243.84, 45.72)
(228.60, 45.72)
(231.14, 45.72)
(246.38, 45.72)
(254.00, 45.72)
(274.32, 45.72)
(287.02, 45.72)
(287.02, 45.72)
The following 4 points have been identified as net connectivity change points from the last operation
日志报警文件!!
Sunny左瞳| | 2014-11-10 10:53 | 只看该作者
log里面有错误的提示,Error,后面的,找出来。我估计有几点错误,没有写封装,或者谢了封装,但是pcb没有对应的封装。线没连好,总之错有很多种啊,你把Error后面的找到,贴出来
